Newbie question, help!
- Newbie question, help!
24-08-2007 11:42 AM
I have a couple of websites that I run from home on my server and everything seemed fine until today
For example, http://www.mr2mk1.net does not seem to be available externally any more (works fine on local LAN). Router and server have been rebooted.
Yesterday I regraded from Premier to Option 2...could that be the cause?!
Sorry if it sounds a stupid question, just looking to eliminate all possibilites...
Thanks, Phil.
Thanks, Phil.
Message 1 of 4
(1,405 Views)
3 REPLIES 3
Re: Newbie question, help!
24-08-2007 11:48 AM
Check if your IP address has changed as premier has a static IP and BBYW has a dynamic by default.
If it is now dynamic, raise a ticket and ask for a static IP again but you may not get the same one so you may need to update any external DNS to point to the new IP.
Message 2 of 4
(459 Views)
24-08-2007 11:57 AM
Thanks for the reply Peter...but i have just fixed the problem!
It appears that my PN Firewall was reset to Low due to the regrade, and that blocks Port 80...
...so I turned it off and Presto
Panic over
Panic over
Message 3 of 4
(459 Views)
24-08-2007 11:58 AM
Hmm... I guess I should have tried the link first... working for me also.
[edit to add] Ah yes, the PN firewall is set to on/low by default for BBYW products. It's caught out a few others so you are not alone.
More general Q to PN...
On a regrade, why do you not keep the PN firewall setting the same when changing products?
Message 4 of 4
(459 Views)
