New "Old" topic - Speed or lack thereof
- New "Old" topic - Speed or lack thereof
Re: New "Old" topic - Speed or lack thereof
07-04-2015 7:07 PM
I dont think anyone is there - they are trainee doctors so may be a long easter break half term ?
Did try the house with the dangle wire to see of they knew anything about it but no-one in.
I have been out with the radio - my down wire is noise from about 2ft the virgin box on the house next door about 1 ft the wire up to the pole from underground similar to my wire.
Did find a monitor sat on its own powered by an adapter- not connected to anything but noisy on the radio and fairly close to the cat5 cable from the router to the pc
I am just going to sit tight until the US is uncapped tomorrow and see what that does.
Townman_ Thanks point noted - laptop and power supply has been unplugged for an hour Bo**ox just looked back at the graph to see if anything changed and to say it is still stuck on 1.5 and NO it isnt
it is back on a margin of 6 wef 7pm
07-04-2015 7:14 PM
Watch out for if tomorrow morning. Do you know if any of the businesses work 08:30 to 7pm? Clutching at straws here, but you need to consider everything.
07-04-2015 7:37 PM
Quote from: Townman That is a "good" change - can you identify anything?
Yes roll on tomorrow - will see what happens then I will go door to door if needs be - what sort of distance . I would imagine just local between me and the cabinet?
as if the whole cable from the exchange was involved the complaints would have been thick and fast?
I should have checked the exchange for problems?
07-04-2015 7:52 PM
Ok Back to Anotherone's post23.
Graceful disconnects - got it now - thanks
Lunged into deep monitoring as I thought it would be a challange to set it up
and it was something to do when nothing was happening - Not much use to me as I dont know how to interpret what they all mean.
As it happens in view of todays new problem it may be of help.
BACK TO BASICS
Up time 9 days. Yes that was one of my Why is this so slow. I had just flown back from OZ 25 hours and another 5 hours to get home
the day before. My son greeted me with "this internet is slow again so I just switched it off. Didnt check anything - in fact then I didnt know how to
"I would not go worrying about exchange or other congestion at this point"
This was not a new worry I have been worrying about that for the last 20 years or so.
On one occasion a well informed Bt engineer advised me that there was no way I was going to get more than 200kbps from a copper telephone wire. I now take anything any Isp or Bt say
with several tons of salt.
"You need to discover why you've been getting low sync events in the first place........
.......Do you suffer from power dips/brown-outs?
I have a sneaky feeling that it may relate back to the power cuts in November. I am not a heavy internet user and it was only when the cheap part of my 18m contract was up and I was paying full price for the last 6 months that I began to think this really is not good.
I go back to the "Up to 17Mb" what percentage of cutomers is that? yes I know its all very clear but when you only get 4mb and at one time used to get 7 its time to start asking questions.
My totally off the cuff idea is that following the power cuts the the DLM increased the target SNRM which lowered my download speeds. As I did nothing about this and just
accepted the low speed was because BT and PN were really only interested in selling Fibre and not in providing a better adsl service, the DLM did not work correctly and think hmm
no cut outs dropped signals for a while the SNRM can be increased, which should have increased my speed?.
Sockets/wiring Only the one socket - I agree the wire to it is old BT 4 wire green brown orange blue - could have deteriorated but did manage 37mbps sky- connected to downwire - approx 3yrs.5mm round black.
Until today I was not going to do anything else until the US had been uncapped as the speed I was getting was back to what it was, or near enough. Now I will have to think again.
07-04-2015 8:14 PM
Quote from: cedlor Ok Back to Anotherone's post23.
That might have been a "hint" towards me - Anotherone and I do good cop, bad cop on some threads - I am more disposed to doing deep monitoring sooner rather than later if I sniff something as being not quite to expectations. With a bit of hand holding it does not need to be to much of a challenge and as you say - in this case - it has shown something very useful. If it had shown nothing, it would equally have ruled out REIN, which is a real pain the bum to locate and fix ,so really good to exclude. You have not been so lucky!
Quote from: cedlor On one occasion a well informed Bt engineer advised me that there was no way I was going to get more than 200kbps from a copper telephone wire. I now take anything any Isp or Bt say with several tons of salt.
To be fair, depending on when you were told that, the engineer would have been reasonably correct; the "voice" spectrum which the copper network was designed for is simply not capable of delivering very much. ADSL is not dissimilar to having lots of 56k modems each carrying a bit of the data, a bit of the bandwidth in parallel, each using transmission bands above that used for voice. That delivers concurrent voice and data and always connected capability, which when your engineer was sharing his knowledge would have been undreamt of. I had been working in IT a few years before we got the ultra high speed 2.4kbps modems from BT which were about 30" cubes weighing around 20kgs.
Quote from: cedlor what sort of distance . I would imagine just local between me and the cabinet? as if the whole cable from the exchange was involved the complaints would have been thick and fast?
I suggest that it is more likely to be closer to the house end, rather than the cabinet, but I do have personal experience of the source being located fairly near to the cabinet.
E-side issues are not unknown, but I think less likely. Sadly finding what you are now looking at is rarely undertaken as ISPs do not have the time / resources to provide the individual help needed to achieve this. I suggest that you have a handle on a problem which could have rattled on for a while without resolution. The problem with REIN is that it is usually considered after everything else has been tried 9and failed) and even then it is hard to find - more often than not, even when specialists turn up the REIN is absent!
No exchange issues do not I think have an impact at present.
Kevin
07-04-2015 9:41 PM
Quote from: cedlor Sockets/wiring Only the one socket - I agree the wire to it is old BT 4 wire green brown orange blue - could have deteriorated but did manage 37mbps sky- connected to downwire - approx 3yrs.5mm round black.
OK, drop-wire fine, old BT 4 wire not. Here is one fundamental problem. It's not twisted pair wiring and will be continually picking up background noise limiting the achievable performance. It doesn't matter what you achieved on Fibre, that was a while ago, things change. Somebody's equipment may have got noisy or some new equipment to your locale may generate noise to which you are susceptible because of this wiring.
The combination of the two and maybe some other occasional spurious noise (REIN or SHINE) is what's been causing you connection to drop. On the resync with the interference present you get a much slower sync speed.
Where (and how) is this joined to the drop-wire out of curiosity. We need to see if we can get something done about it to see how much it reduces the impact of whatever caused the SNRM drop that we've seen today. That may be all that is required.
08-04-2015 10:36 AM
I think I will go back to bed as I have almost lost the plot- mainly as I have no idea what is going on. More tons of salt required.
AND as I write the SNRM is falling rapidly again.- LATER only fell to 3200 but still drifting down
Wife informs me someone is digging the road/footpath up - looks like a water leak 200 meters up the road in the direction of the cab
Another question- could drop in SNRM be due to a drop in signal level as against an increase in noise?
Anyone follow this: who has done what when and why:
Service Notice #225966488
< Back
Service Notification
2:03pm, Monday 6 Apr 2015
An update report has been received for this account.
The broadband service is now being transferred to the 21C Network.
The transfer will complete by midnight on 09/04/2015.
Service Notice #225997676
< Back
12:23am, Tuesday 7 Apr 2015 What time is that? 00.23?
Bandwidth usage has been reset
and another question if there is some problem will the constant pinging from RS increase the number of errors - OK to stop it pinging and see what happens ?
Link Information
Uptime: 0 days, 8:17:06
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,235 / 7,947
Data Transferred (Sent/Received) [MB/GB]: 621.18 / 5.57
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 24.3 / 42.0
SN Margin (Up/Down) [dB]: 6.0 / 2.7
Loss of Framing (Local/Remote): 43 / 0
Loss of Signal (Local/Remote): 5 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 167,454 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 10 / 235,833
HEC Errors (Up/Down): 15 / 458,986
DSL Connection
Link Information
Uptime: 0 days, 9:08:47
Data Transferred (Sent/Received) [MB/GB]: 625.08 / 5.58
SN Margin (Up/Down) [dB]: 6.0 / 2.5
Error Seconds (Local/Remote): 170,396 / 0
CRC Errors (Up/Down): 10 / 411,661
HEC Errors (Up/Down): 15 / 794,906
08-04-2015 11:01 AM
The drop in connection last night seems to be you Upstream speed being uncapped - it's now 1235kb/s (can't get a lot better btw). You did have a slight drop in downstream speed at the time because it was at night when your SNRM was lower.
Why that service notice says "being transferred to the 21CN network" when you are already on it is crazy, but I suspect it has to do with the Upstream Uncapping.
The other Service notice, yes 0023, I assume is because the 7th is the start of your new billing period.
The very poor BTw speedtest might be due to the fact that your REIN is there and is causing CRC errors. It seemed to start at exactly the same time as yesterday. Try the BTw speedtest again.
Don't forget to say where the join from the drop-wire is.
Edit: stop pinging if you want, not likely to be making much difference, or telling you anything of interest at this time.
08-04-2015 12:02 PM
08-04-2015 12:12 PM
08-04-2015 12:47 PM
08-04-2015 1:21 PM
Odd thing is despite the poor figures the internet seems quite usable though have just tried watching Iplayer and it keeps buffering ( I dont think it should, I think the graphics card is up to it but have no previous experience.)
Next time the line appears ok I will have another go to compare.
Problem aside its a lovely day here unfortunately I am instructed to go and cut the grass - Now where did I put that lawnmower - will it work and how much interference will it cause!!!!
Downwire comes pole to eaves down the wall through the wall into the living room to box -see picture- yesterdays pic was the wires out of the box.
3 metres along the end of the room and 3 meters along the hall. Nothing electrical at that end of the living room - socket but only used for vacuuming (sometimes heheheh)
Cant do much about the wire this week as its half term and will have children here from this pm until Sunday pm. Even then I would rather not ( it involves heavy china cabinet/bookcase with hundreds of
holiday souveniers and the wire is papered over for most of its route down the hall.)but as a temporary test I could disconnect and move the master socket to the downwire. ( Probably not allowed to do that?)
Any offers on the could it be caused by a drop in signal as against an increase in noise question?
I am going to be away from this for most of the afternoon - obviously will leave it all running and report back this evening.
08-04-2015 1:24 PM
Quote from: Matthew Just jumping in here but yes 225966488 refers to the upload uncapping,
Ok - but is anything else going to happen between now and the 9th April? or is the action completed.
08-04-2015 1:50 PM
08-04-2015 1:53 PM
