New networking equipment (fttc) - recommendations?
- New networking equipment (fttc) - recommendations?
02-11-2012 1:58 AM
Current setup:
Living Room, 200Mb homeplug connected to a 5 port 10/100 switch, which in turn connects to xbox 360, blu ray player, DLNA capable TV and SnakeOS based NAS (not used often).
Upstairs are two more 200Mb homeplugs connected to two desktop PCs with Gigabit capable integrated network.
In the hall is the OR modem, Technicolor TG582n router which connects to a further 200Mb homeplug.
I also have a Zyxel NSA310 NAS (not currently connected), which is gigabit capable. It had been connected up until last week when I disconnected my old DG834GT router. Just haven't got around to reconnecting it.
I use wifi for a netbook and laptop.
Now I had considered using an alternative router to the TG582n (even before I ordered the fibre upgrade) to get better features and wireless range.
The Asus RT-N56U router seems to get some good reviews and the price isn't out of the question. Any thoughts on it or a better alternative?
I am thinking I need to replace the 200Mb homeplugs with something faster, the 500Mb versions maybe. The ones on 7dayshop seem a good price - http://www.7dayshop.com/7dayshop-500mbps-high-speed-mini-homeplug-powerline-ethernet-network-adapter. Solwise have 1Gb versions on offer 3 for 2 - http://www.solwise.co.uk/net-powerline-gig-pl-1000m.htm.
Or am I better off going for fast wifi adapters to give better throughput than the 200Mb homeplugs?
Happy to replace the 10/100 switch with a gigabit version if need be.
Any thought/tips/advice please?
Re: New networking equipment (fttc) - recommendations?
02-11-2012 1:50 PM
Currently £110 on Amazon, really tempted to buy it.
02-11-2012 1:58 PM
02-11-2012 2:03 PM
Quote from: _Adam_Walker_ would have been a bargain, looks to have some very good specs and features.
I was tempted to just click and go, but I decided to do some homework first and missed out. Had only been used for a week or so.
02-11-2012 4:47 PM
Andy.
02-11-2012 5:16 PM
If it was me I think i'd stick with the powerline adapters. Sadly I don't know anyone who owns a set of 500Mbps or 1000Mbps adapters to give you any feedback.
02-11-2012 7:11 PM
Quote from: g1dtf I am currently using a Thompson 586v8 in bridge mode (modem only) and feeding it to the WAN port on the N66U. The wireless range on both 2.4 and 5ghz is great, the speed also seems ok but will know better when I get my fibre installed.
Andy.
Thanks Andy for user feedback. Be interesting to know how the speeds, etc are when on fttc.
Quote from: Alex If it was me I think i'd stick with the powerline adapters. Sadly I don't know anyone who owns a set of 500Mbps or 1000Mbps adapters to give feedback.
Thanks for reply Alex. I have found some 500Mb ones on eBay for similar money to 200Mb ones. Tempted to buy a pair and see what results I get.
02-11-2012 7:52 PM
02-11-2012 11:27 PM
I have my modem and router in the living room. The router has wired connections to a NAS, BluRay player and some other stuff. My main laptop is usually about 10m away from the router, not quite in line of sight. Upstairs, separated from the router by a 14" thick solid brick wall, I have 2 PCs, wired to a wireless bridge (a Dlink DAP 1522).
Speeds:
wired directly into the modem, I can get pretty much full rate (73Mb/s)
wired directly into my router, a bit less, but still 70+. Incidentally, although I don't use it, my 582n is a little faster than my own router, wired
the laptop, wirelessly, manages 60+
the PCs upstairs also manage 60+
So it is possible that better wireless kit could outperform at least your current powerline adapters.
I would leave your powerline connection to the living room 10/100 switch as none of the kit attached to that will ever demand much bandwidth.
But I would (I did) certainly invest in a router with better wireless performance than the 582n. I like routers with several physical aerials; I distrust those with internal aerials (though the DAP 1522 obviously performs adequately so internal aerials can be made to work well). I also don't expect any ISP to provide a router that can match the best available on the open market.
03-11-2012 2:43 PM
Quote from: w23 Results with any powerline adapters will depend, to some extent at least, on your house wiring. Separate ringmains can reduce speed between the two. Of course, there's always the 'unknown' of interference on the house wiring.
Yes, I know they can vary a lot. However I can't be dealing with cat5e cables running all over the house. I started out with the 85Mb versions and soon changed to 200Mb when i knew how they worked in my property.
Quote from: AxeMurderer I'm going to weigh in with an alternative viewpoint.
Speeds:
An interesting viewpoint and if I replaced the router with something better I could maybe try that out for myself.
For reference I am looking at the TRENDnet TPL-401E2K homeplugs, they seem to perform pretty well according to smallnetbuilder.
04-11-2012 10:43 AM
My problems are similar to yours, in that I have a little office at the end of a ground floor extension, where my three main desktops are (two Windows and one Linux server). I've got network-aware Blu-Ray, Sky Box, and a chipped Xbox v1 (running XBMC) in the living room, my son has an Xbox 360 and laptop upstairs, and there's a FreeNAS box in the garage.
When we were on ADSL we used 85Mb Homeplugs all over the house, which gave us around 50Mbps transfer speed, but when we moved to 40Mbps FTTC we found that we were getting 32Mbps directly from the router, but only 20Mbps through the Homeplugs, making them a bottleneck.
I took the plunge and replaced them all with 200's, which was quite expensive as I had 4 to replace, plus we also had a wireless extender allowing decent wi-fi access in the rest of the house . This was because our router is in the extension, outside the original double-skin wall of the house, and it's wi-fi signal simply didn't reach.
Anyway. Replaced 4 Homeplugs (and the wireless extender) with 200Mbps versions, and immediately noticed that I was only getting 20Mbps through the Homeplug network. Since 20Mbps was a massive improvement on the previous 2 I wasn't that bothered. However I decided to try a couple of 1Gb Homeplugs, since Solwise's web page said they were compatible with the existing 200 network. Well they weren't. I could not get them working in tandem. So I quickly sold them off to a mate who just wanted a 2 Homeplug solution. I'm sticking with the 200's for now.
My suggestion is that if you're going to try 1Gb Homeplugs, you'll be better off replacing the lot. Homeplugs still fetch a good second-hand price on eBay (especially the 200AV's) so you'll get some of your money back.
Luckily for us, we're in the process of extending over the garage, and the builder says he can build 4 CAT5 extensions in, removing the need for almost all of our Homeplugs. Yay!
-Dave
You know what a turtle is? Same thing.
04-11-2012 11:10 AM
Quote from: lorisarvendu Hi vultura
I took the plunge and replaced them all with 200's, which was quite expensive as I had 4 to replace.
-Dave
Thanks for the reply Dave.
I am aware that I would need to upgrade all of the homeplugs, as I have read the co-existence side of things isn't great. I mentioned buying a pair to test the speed, well I would unplug the 200s whilst I did so. Then if they tested ok just order a 2nd pair.
04-11-2012 11:12 AM
Quote from: lorisarvendu Luckily for us, we're in the process of extending over the garage, and the builder says he can build 4 CAT5 extensions in, removing the need for almost all of our Homeplugs. Yay!
Cat5e, I hope!
04-11-2012 11:33 AM
04-11-2012 11:42 AM
