New line VERY slow against estimated line speed, HELP Please.
- New line VERY slow against estimated line speed, H...
13-09-2009 11:59 AM
Now I have a fairly good idea why this might have happened. They have their router at the top of the house connected to the only BT socket at the bottom of the house via what appears to be a 15 metre extension cable. Is this likely to be the culprit?
I plan to take a wireless adapter around, move the router to the master socket at the bottom of the house and test if they can connect to it wirelessly from the top of the house. If that works ok then get them to buy their own adapter.
So the router will probably move temporarily for the test then permanently after they get wireless adapter kit. What process do I need to go through to get the line speed to re-train or is this automatic and how long will it take?
Cheers
Peter
Re: New line VERY slow against estimated line speed, HELP Please.
14-09-2009 10:23 AM
With the router installed where it is go to the stats page and then try ringing their phone number to see if that affects the stats.
I presume that they have a doubler in the master socket, the extension with a filter at the top of the house in to which the router is plugged. Do they have a phone or anything else plugged in at the bottom of the house and if so is it filtered as well?
14-09-2009 10:34 AM
Mind PMing me with the referrals username so I can run a couple of quick checks on their telephone line?
14-09-2009 10:35 AM
14-09-2009 10:35 AM
Quote from: Jameseh Hi Peter,
Will do James, Cheers.
14-09-2009 10:51 AM
Quote from: God the other (unfiltered) goes straight to the top of the house to the router.
Where there's another filter I hope!
14-09-2009 10:54 AM
As I mentioned, you'll need to eliminate the internal wiring issues. It doesn't look that bad from the line tests though.
14-09-2009 10:55 AM
14-09-2009 11:18 AM
Comparing the stats when the router is upstairs and when it's directly in to the master socket is a must.
<enormous understatement warning>Some extension leads are not very good.</enormous understatement warning>
18-09-2009 9:15 AM
@jelv: Why would he want a filter for the router? I thought all routers have inbuilt filters.
18-09-2009 9:56 AM
18-09-2009 10:02 AM
This should be fitted by BT though as it replaces their box which you should not touch, there are though lots of instructions on how they would do it if you paid them
I've also been looking at the i-plate, this is legal to fit as it just plugs into the one you have. Have a search fot it theirs plenty about roughly about £5ish quid, they do require filters so again look for better quality ones.
