New join on 1st
- New join on 1st
Re: New join on 1st
21-07-2013 10:38 AM
Re: New join on 1st
21-07-2013 10:41 AM
Re: New join on 1st
21-07-2013 10:52 AM
Re: New join on 1st
24-07-2013 7:22 PM
every speed test i do i get 46-49mb now
Estimated line speed:
69Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-06-30 19:58:42
Current line speed:
70.8 Mb
this has dropped as well from 76mb to 70
i use to get 76mb in speed test before
Re: New join on 1st
25-07-2013 11:54 AM
That'd definitely be something we should raise to our suppliers for investigation, if you could run through the faults wizard at http://faults.plus.net once the questions have been answered it'll raise a ticket through to our faults team and we'll get it reported for you.
Re: New join on 1st
25-07-2013 5:38 PM
is there anyway you can bump it back up i changed the socket for the modem and router
thank you
Re: New join on 1st
25-07-2013 6:16 PM
For your connection, the acceptable range of speedsis 16 Mbps-40.85 Mbps .
Additional Information:
IP Profile for your line is - 40.85 Mbps
Upload speed achieved during the test was - 12.81Mbps
so is my upload capped as i never sen it go higher then 12-14mb
my cab is about 50 feet away from my house in straight line
and 100 if your drunk
so i should get full speed 80/20 right? the guy that came showed me full speed as well
Re: New join on 1st
26-07-2013 11:38 AM
Re: New join on 1st
26-07-2013 12:14 PM
i just done a speed test and it is at 40mb now
Re: New join on 1st
26-07-2013 3:34 PM
Re: New join on 1st
27-07-2013 8:27 PM
since it is at IP Profile for your line is - 40.85 Mbps right now
Re: New join on 1st
28-07-2013 3:05 PM
can you change the IP profile to 76-80 MB thank you
Re: New join on 1st
29-07-2013 5:09 PM
Re: New join on 1st
05-08-2013 1:46 PM
Not happy
Re: New join on 1st
06-08-2013 11:28 PM
Phone exchange:
SOUTHALL
Current line speed:
33.8 Mb
got a guy coming tomorrow i hope since 1 didn't turn up on 5th
