New install, slow speeds.
- New install, slow speeds.
- « Previous
- 1
- 2
- Next »
Re: New install, slow speeds.
02-05-2014 9:15 AM
@Josh1821 - We're still seeing a large number of drops on your line as seen below:
<img src="http://community.plus.net/visualradius/generated/image13990184431908.png"/>
Would you be able to connect an alternative microfilter in the first instance and see how things are for an hour or two?
02-05-2014 3:14 PM
02-05-2014 3:18 PM
02-05-2014 3:24 PM
02-05-2014 3:25 PM
It is best if you can borrow a phone to test, just to be on the safe side.
02-05-2014 3:55 PM
PS is there a reason why my ISP listed through speedtest.net sometimes changes from PlusNet Technologies to INFONET Services Corporation?
02-05-2014 4:11 PM
This problem has been known about for a few weeks.
Given that you are on a dynamic IP service, speedtest.net will reflect the "owner" of the IP you have at the time of the test.
02-05-2014 4:22 PM
EDIT: Ok, quite a strange development. I plugged in the Sky router to see what happened and I've reconnected to sky broadband, acheiving 800kb/s download speed. As far as I'm aware this should have been de-activated on Wednesday, could this be the cause of the problem or more to do with the router? Speedtest.net is showing no problems whatsoever, apart from the connection drops that aren't really hindering in any way I think this rules out my internal wiring and set up as the cause.
02-05-2014 7:21 PM
02-05-2014 9:05 PM
02-05-2014 9:22 PM
07-05-2014 11:11 AM
<img src="http://community.plus.net/visualradius/generated/image13994573762782.png"/>
Is everything working as expected now?
07-05-2014 1:05 PM
Is that router a PN supplied one?
07-05-2014 2:13 PM
If the router is faulty, it can be replaced.
- « Previous
- 1
- 2
- Next »
