New fibre install
GeordieMark
New fibre install
Hi guys,
Just had fibre installed, we're only getting 5Meg up and 50 down (which I can live with) however the openreach guy even said the download is a bit low but didn't say what could be done about it.
Would someone be able to have a look at my line see if there's anything we could do to squeeze a bit more out the line?
39 REPLIES 39
Pettitto
Fixes: 5
Re: New fibre install
Can you restart your Plusnet Router please to see if things are any better please?
GeordieMark
Hi Chris, No chage unfortunately Sad
http://www.speedtest.net/my-result/3655244066
Pettitto
Fixes: 5
Is that via Ethernet?
GeordieMark
It is yep, I noticed on the BTW checker my IP profile is 50Mbps, which will explain why I'm only hitting 48, do you think (looking at my line stats which I can't see until I unlock the modem) The line could go nearer the estimated 60?
However there's definitely something not right with the upload by the looks of it.
Pettitto
Fixes: 5
Hmm yeah, I'd raise a fault so we can have a look at it in more detail for you.
You can do this at http://faults.plus.net
GeordieMark
Cheers Chris, just done this now.
As for the download, is it just a case of waiting to see what DLM thinks of the line and updates it? By any chance could you attach the line statistics for the line? Thanks
Pettitto
Fixes: 5
Sure, it's attached. The line is erroring, so I think if we wait to see what the Faults Team come back with you can compare what I've attached with their findings?
Also, please ignore a ticket I created on your account a few minutes ago, I've since closed it!
GeordieMark
Thanks Chris, Yeah I did get confused by that haha.
According to the ticket it's been raised with supplier (I assume openreach)
Test Result: Fail - Fault located in local network
Description: FAULT - Battery Contact
From past experience this could be a wet joint or something?
Pettitto
Fixes: 5
Yeah, that's right - that wasn't meant to have been raised on your account, your broadband line is still in testing with our suppliers though Smiley
GeordieMark
Ah right yeah, I see that one has disappeared now.
I'll wait to hear back from you guys, thanks Chris Smiley
GeordieMark
Chris, looks like it's set my profile back to my old ADSL one overnight, capped at 4.5Mbps down with the 5.5Mbps up and my member centre reflects this, could you give it a nudge please?
Cheers
Pettitto
Fixes: 5
Can you please PM me your account username please? I can't locate your account for some reason 😕
GeordieMark
Done  Smiley
Pettitto
Fixes: 5
Thanks - profile updated Smiley
