New fibre install. Slow speed check speeds
- New fibre install. Slow speed check speeds
17-12-2013 4:48 PM
Hi, I had a new install of fibre today but the speed seems a bit slow. My "high speed broadband" page has a current line speed of 78Mb but after running a speed check the quickest I can get is:- download 7.45Mbps upload 1.68Mbps with 46ms ping. Download speed about the same as my old adsl speed. Does the 10 day training period apply for fibre too. Thought I would at least get above 40Mbs download being on the same street as cabinet?
Thanks for any help.
Message 1 of 5
(882 Views)
4 REPLIES 4
Re: New fibre install. Slow speed check speeds
17-12-2013 5:16 PM
Hi toonspark,
Sorry to hear about the speed issue.
Definitely not
I've checked the account and can't see any issues that might have caused this. I can see you've raised a fault so bear with us and our faults team will be picking that up ASAP.
Quote Does the 10 day training period apply for fibre too.
Definitely not
Message 2 of 5
(441 Views)
17-12-2013 5:18 PM
Thanks for the quick reply Adam, I didn't finish the fault request so ill do that now. Hopefully an easy fix.
Message 3 of 5
(441 Views)
17-12-2013 7:50 PM
Hi Adam, seems to have been a problem with my router. Don't know what it was though. I connected the open reach modem straight to my computer and set up a pppoe connection. Speedtest of over 45Mb :). Reconnected my router and the speeds stayed the same Weird. Thanks for the help any way and can you cancel my help ticket.
Message 4 of 5
(441 Views)
17-12-2013 11:28 PM
Since you raised the fault ticket all support can do is return it to you. If you go to https://portal.plus.net/wizard/?p=search you should find the ticket there with an "issue resolved" link beside it. Click that link to close the ticket.
David
Message 5 of 5
(441 Views)
