New customer - wireless drop outs - Netgear DGN1000
- New customer - wireless drop outs - Netgear DGN100...
27-03-2013 9:21 PM
Looking for some assistance.
Was with sky but moved to plus net last week. Previously with a sky router, no problems whatsoever. Skys router is locked down, and cannot be configured manually, therefore i've had to move back to my Netgear DGN1000.
I have the PS3 connected to the router via ethernet cable, and although there aren't any disconnections in online game play, there is a lot of lag at certain points. Coincidentally, the wireless drop outs/disconnections i'm getting on laptop and on all mobile phones connected, seem to happen around the same time as the lag in gameplay.
I am also getting a lot of disconnections to the router on laptop and mobile phone when the PS3 is not in use.
Has anyone had these problems before?
I reset the router back to factory settings, then updated the firmware on it, and then basically entered my account details into the router configuration. I haven't changed anything else.
Is there anything I need to change that would currently be causing the drop outs/disconnections?
Thanks in advance,
Luke.
Re: New customer - wireless drop outs - Netgear DGN1000
27-03-2013 10:08 PM
27-03-2013 11:05 PM
28-03-2013 9:15 AM
Quote from: ReedRichards You could try changing the wireless channel.
I'm not sure that will make much difference
Quote from: luke222010 I have the PS3 connected to the router via ethernet cable,
02-04-2013 10:50 AM
02-04-2013 11:11 AM
02-04-2013 11:16 AM
Quote from: _Adam_Walker_ I've just checked the connection itself and that looks fine and has been connected currently for over 48 hours. What are your connection speeds like in general?
Adam
In the first few days the speed was around 4-5mb which is around 2mb slower than I'm used to. I know generally they fluctuate in the first two weeks so this doesn't worry me. Online gaming I am experiencing a lot of lag, and wondered whether interleaving would fix this. However, I've read from quite a few people that the DGN1000 is a troublesome router with wireless drop outs which is my main problem at the moment.
Can I sort a new router via this forum or do I need to ring customer services? Is there a router I need to ask for specifically?
Thanks,
Luke.
P.s. I tried switching the wireless channel to one that isn't used and still had the same problems.
02-04-2013 6:31 PM
Adam
Thanks,
Luke.
Okay, just checked speeds, and they're quicker than before as expected:
DownStream Connection Speed 7256 Kbps
UpStream Connection Speed 444 Kbps
Tested some gaming out and it seems a bit more stable.
As for the Wi-Fi drop outs i'll keep an eye on them tonight.
Can a mod sort me a new router out on here or do I need to call customer services for that?
02-04-2013 8:05 PM
If you haven't had a Plusnet router in the last 12 months you should be able to order one (a TG582n) by giving the CSC a ring (0800 432 0200). The P&P charge of £5.99 would need to be paid by card with the £40 cost written off if you stay for 12 months.
03-04-2013 11:22 AM
