New customer - speed ok(ish) but some websites simply not opening
- New customer - speed ok(ish) but some websites sim...
Re: New customer - speed ok(ish) but some websites simply not opening
07-06-2015 6:48 PM
07-06-2015 8:48 PM
Quote from: Bob There are isolated instances of the incorrect MTU being set by the TR069 ACS servers when a router is first provisioned.
I don't know a great deal about the problem but I'm led to believe that it's been addressed in the next revision of the Plusnet 2704n firmware.
Hi Bob,
How isolated?
There seems to be a number of similar reports sound the forum - are the support channels fully aware of the issue? Do they know what to look for and then how to fix please?
Is there a systematic way that this issue can be identified and fixed before users see it? Is there anyway of users verifying if this problem impacts them?
Is there a plan to replace the 2704n with something more useful (no errors, supports telnet, works with RouterStats and the like) soon please?
Cheers,
Kevin
07-06-2015 9:13 PM
I hope you're not just greedily wanting a better router for free - I think most things people have said in defence of the 582n could just as easily apply to the 2704N.
07-06-2015 9:26 PM
I rather think you quote me out of context. Im sure that you would not disagree that the 2704n is restricted in the extreme. One is not asking for a high spec router )which was the point of discussion in the other thread) rather a router which has just a similar level of functionality as the TG582n with accessibility to useful information to diagnose problems.
Yes someone could write a programme, but why reinvent things which already exist? If it were not for the restrictions in the PlusNET firmware I'm sure that existing tools would be quite adequate.
Having a dig at me does not help people looking for help. But that is an old discussion.
Cheers,
Kevin
07-06-2015 9:31 PM
Quote from: Townman Is there a plan to replace the 2704n with something more useful (no errors, supports telnet, works with RouterStats and the like) soon please?
How can you possibly imagine that they may even have a plan to do that when Bob has made it clear that there will be a firmware update in pipe for the 2704n!
07-06-2015 10:00 PM
07-06-2015 10:12 PM
So all you can do it dig up some very old threads about the 582n, nobody said it was perfect. We've been here before - it's a BUDGET router BUT it does work better than the current 2704n and gives far better diagnostics.
Give it a rest please and try and post something constructive, eg. how can the average user simply check if the MTU on the 2704n is wrong? - and remember these users aren't all technical whizz-kids!
Edit:spelling!
07-06-2015 10:37 PM
I'm sure using the ping command starting with the maximum packet size and working down would be declared to difficult. But that's what I can expect from people who tell me to go and do my homework and then ask me to do theirs.
07-06-2015 11:07 PM
08-06-2015 10:34 AM
08-06-2015 12:12 PM
Quote from: ChrissyR Dont know where to go from here
I've made some changes to your account, can you try the problematic sites again and let me know if you're still encountering problems?
Quote from: Townman
Hi Bob,
How isolated?
I'm not 100% sure TBH, I know it's not happening in all cases though. Having said that, it seems to affect all current FTTC firmwares where the user switches to ADSL mode via the GUI.
Quote from: Townman There seems to be a number of similar reports sound the forum - are the support channels fully aware of the issue?
I've seen a few briefs being circulated so they should be.
Quote from: Townman Is there a systematic way that this issue can be identified and fixed before users see it?
Not to my knowledge.
Quote from: Townman Is there anyway of users verifying if this problem impacts them?
Well, the easiest way would be to try browsing to some of the problematic sites. Another option would be to try pinging certain sites using various packet sizes as mentioned by @ejs.
There are no short/medium term plans to replace the 2704n with another device.
08-06-2015 12:15 PM
Bob
Quote from: Bob I'm not 100% sure TBH, I know it's not happening in all cases though. Having said that, it seems to affect all current FTTC firmwares where the user switches to ADSL mode via the GUI.
Is the reverse the case - using the GUI to change from ADSL to Fibre
08-06-2015 12:44 PM
08-06-2015 12:46 PM
08-06-2015 2:08 PM
