New customer, speed issue.
- New customer, speed issue.
- « Previous
- 1
- 2
- Next »
Re: New customer, speed issue.
05-02-2008 2:36 PM
Barry line stats are:
DSL Connection Details
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT Annex A
Downstream Rate: 4640 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 15.0 dB (Downstream), 23.0 db (Upstream)
Current Attenuation: 44.1 dB (Downstream), 26.0 db (Upstream)
Current Output Power: 19.8 dB (Downstream), 12.1 db (Upstream)
DSLAM Vendor Information: Country: {0xB5} Vendor: {TSTC} Specific: {0x00}
PVC Info: 0/38
I normally leave my router on 24/7, will i need to reboot a few times for the IP Profile to change?
Thanks.
PVC Info: 0/38
Thanks.
Message 16 of 18
(212 Views)
05-02-2008 2:50 PM
If your line is being retrained, it's worth rebooting the router once a day - usually a good time to do this is during the daytime as SNR stats often deteriorate during the evening and night-time.
Stats look good for stability though
B.
B.
Message 17 of 18
(212 Views)
05-02-2008 3:17 PM
Jameseh, just tried some P2P downloading and it peaked at around 160kpbs, only let it download for 5 minutes, so it may go faster once it gets in its stride. I will start it again at midnight and see what its like then.
Barry, thanks, will reboot each day then. Just had to reboot now as this new router threw a fit, dont think it likes P2P
Its synced at 4864kbps now, so hopefully it will stay similar to this from now on.
Message 18 of 18
(212 Views)
- « Previous
- 1
- 2
- Next »
