New customer - slow/stuck Upstream
- Re: New customer - slow/stuck Upstream
29-04-2013 11:13 AM
I have just kicked off surfing with plus.net and noticed my Upstream has not increased since day 1 (Activation) whereas my downstream rate is between 7-15Mbps.
The slow Upstream affects my Skype calls and I am sure could be more (like ~1Mbps).
Let me share with you my stats and can I ask for your suggestions of what could be wrong (can I get more upload speed, is it stuck IP profile I read about, etc. ?).
(see attachments).
I am on standard Residential Broadband *(up to 16Mbps).
http://www.mybroadbandspeed.co.uk/results/189456151.png
BTW Perf test:
Download speed achieved during the test was - 9.27 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 11.25 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
Router stats:
ADSL2Plus, Annex A
S/N: 6.4db Down, 24db Up
Line Attn: 22 Down, 12.9 Up
Cheers,
Marek
username: mareknowak
(see attachments).
BTW Perf test:
Router stats:
ADSL2Plus, Annex A
Cheers,
Marek
Message 1 of 6
(1,373 Views)
5 REPLIES 5
29-04-2013 11:40 AM
Those CRC errors look high (Image 1), but there is no indication of a time period (is it a TP-Link? - if so, the upstream CRC errors may not be significant and you may need to use Telnet to get additional info).
You probably need the upstream to be uncapped to get more than 448, if it isn't already and probably worth trying a quiet line test (dial 17070 option 2 if available) to check for noise.
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 2 of 6
(626 Views)
29-04-2013 12:06 PM
1. CRC errors - yes, its is a TP-Link, so I would not worry too much about CRC.
2. Just did a Quiet Line Test - no noise.
(I have only 1 phone & 1 router connected to the line).
= Uncapping the upstream looks like a viable option then.
Stats from the router via CLI:
TP-LINK> wan adsl linedata f
relative capacity occupation: 100%
noise margin upstream: 25.9 db
output power downstream: 0.0 dbm
attenuation upstream: 12.9 db
TP-LINK> wan adsl perfdata
near-end FEC error fast: 46518
near-end FEC error interleaved: 0
near-end CRC error fast: 9308
near-end CRC error interleaved: 0
near-end HEC error fast: 26605
near-end HEC error interleaved: 0
far-end FEC error fast: 0
far-end FEC error interleaved: 0
far-end CRC error fast: 65420
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
Error second in 15min : 9
Error second in 24hr : 764
Error second after power-up : 1098
ADSL uptime 17:03:36
TP-LINK> wan adsl chandata
near-end interleaved channel bit rate: 0 kbps
near-end fast channel bit rate: 12753 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 443 kbps
Regards,
Marek
Regards,
Marek
Message 3 of 6
(626 Views)
29-04-2013 12:16 PM
To answer the original question - raise a ticket here asking that your upstream is uncapped https://www.plus.net/wizard/?p=wizard&page=22883&wizard_id=38
Message 4 of 6
(626 Views)
29-04-2013 5:09 PM
Hi Marek,
Welcome to Plusnet and our community forums
I've placed an order to uncap your speeds and also updated your ticket.
Chris
Chris
Message 5 of 6
(626 Views)
30-04-2013 8:43 AM
Update 30/04/2013 08:42
Problem resolved - Upstream uncapped.
near-end fast channel bit rate: 15659 kbps
far-end fast channel bit rate: 1087 kbps
Thank you.
Marek
Thank you.
Marek
Message 6 of 6
(626 Views)
