New customer cannot connect to internet
Crawfy99
I joined plus met a few days ago and everything has been working fine until sometime today. Now the router says it is disconnected. I’ve reset the connection and it’s reverted to setup@plusdsl.net. Please can someone help - my kids are giving me severe grief!
Andy
6 REPLIES 6
Gel
Aspiring Champion
Fixes: 29
Re: New customer cannot connect to internet
Check the Router log in details correspond with those supplied to you by PN. If it's PN's Hub One
router that should be set automatically for you. It's NOT "SETUP@" but your username@ etc.
Check troubleshooting link below too if necessary.
Crawfy99
I’ve managed to get hold of support and they told me the account was in a queues activate state and it would take a couple of hours to clear. That was 7 hours ago and the problem still exists!
LaurenB
Fixes: 131
HI @Crawfy99 sorry to hear you was having issues.
You look to have an active connection now, is everything OK your end?
 Lauren Barry
Fixes: 160
@LaurenB
Is that "active" solely in the context of you can see an active RAS session (which might have been attained by a manual change to the router settings) or consequential to fixing whatever was in habiting auto-configuration?  has the user's router serial number registration been verified?
@Crawfy99
A warm welcome to the forums.  Which router are you using please?  Did you attempt to connect the router BEFORE being advised that the service was active?
Crawfy99
It all appears to be working now, thanks
Fixes: 1,600
I'm glad to hear that Andy.
Please let us know if you need any further help.
