New Tecnicolor Router
- Re: New Tecnicolor Router
14-11-2013 4:38 PM
Have a new router from Plusnet and my whole thing is very slow My profile being a fraction of what it was.How should I proceed
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
0.49 Mbps
0 Mbps 0.5 Mbps
Max Achievable Speed
Download speedachieved during the test was - 0.49 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :0.8 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
Download Speed
0.49 Mbps
0 Mbps 0.5 Mbps
Message 1 of 7
(1,137 Views)
6 REPLIES 6
14-11-2013 4:40 PM
Have you had connection problems recently?
Your speeds are slow because BT have set your IP Profile to 0.5Mb/s. Can you put your number in http://www.dslchecker.bt.com/ and see what it says about your estimated speeds?
Message 2 of 7
(697 Views)
14-11-2013 4:47 PM
If you post the full stats from your router - noise margin, speeds and attenuation we would have a better idea http://192.168.1.254/cgi/b/dsl/dt/?ce=1&be=0&l0=1&l1=0 takes you to the right page
Message 3 of 7
(697 Views)
14-11-2013 4:52 PM
Link Information
Uptime: 0 days, 0:49:07
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 800
Data Transferred (Sent/Received) [MB/MB]: 2,90 / 14,58
Output Power (Up/Down) [dBm]: 11,9 / 14,4
Line Attenuation (Up/Down) [dB]: 31,5 / 63,5
SN Margin (Up/Down) [dB]: 12,0 / 12,1
Chipset Vendor ID (Local/Remote): BDCM / ALCB
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 67 / -
FEC Errors (Up/Down): 46 / 4.866
CRC Errors (Up/Down): 22 / 61
HEC Errors (Up/Down): -2 / 61 / 27
Message 4 of 7
(697 Views)
14-11-2013 4:56 PM
Are you connected to your master socket? Can you hear any noise like crackling or static on your phone line?
Your line is very noisy - actually off the scale. I don't think routers report anything above 63.5dB.
Message 5 of 7
(697 Views)
14-11-2013 4:56 PM
Judging by your attenuation and noise margin the speeds aren't too bad
However for some reason your default noise margin has increased to 12dB
Did you do a manual resync about 49 minutes ago or did the line just drop
Message 6 of 7
(697 Views)
14-11-2013 5:03 PM
We fixed up the new Router then and it has been all down hill it is in the main BT socket with a filter, phone OK I am on a long line but it has been acceptable until now
Message 7 of 7
(697 Views)
