New TP-Link modem router, very inconsistent ping when gaming.
aguirre
I bought a new TP-Link Archer VR600, set it all up. General internet browsing/streaming is quick. But when I am gaming, the ping will go from 40 to 150, right up to 1200 then back down 40.
Does it on both Wifi connection and ethernet connection
I dont know if i have made a mistake with router set up
looking for help!
5 REPLIES 5
aguirre
Re: Now TP-Link modem router, very inconsistent ping when gaming.
Current Rate(kbps) 1102   6510
Max Rate(kbps) 1108    7224
SNR Margin(dB) 6    6.7
Line Attenuation(dB) 23.4    40
Errors(pkts) 3616    48143
Chris
Legend
Fixes: 169
Have you double checked that nothing is using the upload whilst you're gaming? If anything saturates the upstream you may see ping spikes or similar.
aguirre
99% no other devices are uploading. i have changed all adsl filters etc to no avail. . .
currently sitting at a consistent 200 ping which for fps games online is NOT good.
aguirre
nothing to add? anyone? modem router settings which i can cross reference to make sure everything is correct? its highly unusual that even with ethernet there are lag spikes.
Fixes: 1,600
Were you experiencing this problem with your previous router?
