New Router
- New Router
New Router
25-02-2008 6:59 PM
On Friday, my Billion router gave up and failed on me. I've ordered a new Netgear one and while I'm waiting for it to come, I'm using an old Binatone broadband modem. The downstream rate is about 1300 which is lower than I was getting on the Billion. I'm presuming that when I connect my new router I'll have to go through the 10 days retraining? Am I correct?
Message 1 of 3
(817 Views)
2 REPLIES 2
Re: New Router
25-02-2008 7:01 PM
No, the 10 day training period is only for new adsl connections. It may be that your older router is more susceptible to noise and interference in which case your line profile (and therefore speed) may drop slightly, but this should pick up again shortly after you reconnect your new equipment.
Hope that helps,
Hope that helps,
Message 2 of 3
(254 Views)
Re: New Router
25-02-2008 7:01 PM
Nope. The 10 day training only happens when you first get switched to ADSL Max.
Message 3 of 3
(254 Views)
