New Modem/Router question
- New Modem/Router question
- « Previous
- 1
- 2
- Next »
Re: New Modem/Router question
13-07-2008 7:31 AM
Quote from: bobboulby I'm not sure how to measure the latency though.
As Nick said get your (Packet InterNet) Gopher to measure it for you;
ping -n 25 -l 4096 ipaddressorhostname
"-n" increases the number of packets, as 4 is ok if you are just checking that a device is live and responding on the network, but to check latency I suggest between 25 and 100.
"-l" increases the packet size to 4K on a local network 64 bytes is to small for any real indication.
13-07-2008 7:33 AM
Pinging ***.***.*.* with 4096 bytes of data:
Reply from ***.***.*.*: bytes=4096 time=78ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=117ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=124ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=81ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=70ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=43ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=5ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=369ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=199ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=7ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=42ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=177ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=105ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=45ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=6ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=9ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=73ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=123ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=93ms TTL=255
Reply from ***.***.*.*: bytes=4096 time=84ms TTL=255
Ping statistics for ***.***.*.*:
Packets: Sent = 30, Received = 30, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 5ms, Maximum = 369ms, Average = 63ms
My Son plays games on line and it sems to work ok though. I'm no gamer myself so it's difficult for me to comment.
Bob
[Edit to include results from increase in packet size to 4096]
13-07-2008 7:58 AM
Also for comparison, I thought it might be interesting to post some results from pinging his PSP over wireless.
Bob
13-07-2008 8:19 AM
For comparison, ping to my router over a 100M hard-wired link
Packets: Sent = 25, Received = 25, Lost = 0 (0% loss),
Minimum = 2ms, Maximum = 2ms, Average = 2ms
13-07-2008 8:36 AM
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 1ms, Maximum = 3ms, Average = 2ms
13-07-2008 10:39 AM
25 packets transmitted, 25 received, 0% packet loss, time 24001ms
rtt min/avg/max/mdev = 3.192/3.424/4.387/0.230 ms
When I ping the modem (I have separate modem and router devices):
25 packets transmitted, 25 received, 0% packet loss, time 24002ms
rtt min/avg/max/mdev = 3.667/4.551/5.740/0.553 ms
13-07-2008 10:50 AM
Powerline to PS3
Minimum = 4ms, Maximum = 117ms, Average = 11ms
Wireless to PSP (35% signal strength) Note the PSP is next to the PS3 in this test.
Packets: Sent = 30, Received = 24, Lost = 6 (20% loss),
Minimum = 39ms, Maximum = 181ms, Average = 87ms
Wireless to PSP (95% signal strength)
Minimum = 13ms, Maximum = 20ms, Average = 16ms
Interesting. The conclusion seems to be that Powerline is better than wireless when signal strength is low, otherwise wireless gives better (more consistent) results.
Bob
15-07-2008 4:55 PM
I’ve very recently upgraded my old W98 set up that had an integral card (just before it died completely) to a new Vista pc with a Netgear DG834G Wireless ADSL Modem /Router. All of this is, I’m delighted to say, working perfectly and the speed I receive has almost doubled. On checking my usage at the Members Centre I notice that there is download and upload figures even when the pc has not been used at all, how does this happen?
15-07-2008 4:59 PM
That must be a bit of a shock when using your first router!
That's actually quite common - Routers send and receive small bits of data continually, but this shouldn't add up to much.
I wouldn't worry about it too much.
15-07-2008 6:30 PM
I won’t be concerned.
Yes it was a bit of a I can’t believe how quick everything is! Office 2007 is making my head spin a bit though!
Again, thanks for your help James
Rob
- « Previous
- 1
- 2
- Next »
