New Fibre Installation - Speed away from router
- Re: New Fibre Installation - Speed away from route...
04-04-2013 9:09 AM
Hello, we had PlusNet Fibre installed yesterday and all went fairly smoothly. The router - Technicolor TG582n FTTC - is sitting in the office and I ran the recommended BT speed test http://speedtest.btwholesale.com/ while plugged straight into the new router and the DL speeds were about 72Mbps which is great Previously with O2 ADSL we were only getting about 12Mbps.
However for all other computers and devices in the house that are not plugged directly into the router it's not so great
Firstly
HomePlug - Up until to now I'd been using HomePlug to get the broadband around the house to another couple of PCs using several of these http://www.amazon.co.uk/Max-Value-Mbps-Home-Double/dp/B000TV7FJ4 . My previous broadband speed (O2 ADSL) was limited to about 12Mbps (we're fairly close to the exchange) and the HomePlug adapters seemed fine (I got pretty much the same speed whether at the main router or out of a HomePlug adapter). Now however with 72Mbps at the new router I am only seeing about 20Mbps out of the HomePlug adapters. I've tried plugging them into various different wall sockets and 20Mbps seems to be the top speed I can get. So do I need better HomePlug adapters? Or is my house wiring the limiting factor in all this?
Secondly
Wireless - There are also several wireless devices (Kindles/ Andorid Tablets etc) scattered throughout the house. I've checked speed on these and they seen to have a maximum DL speed of about 10Mbps. Should the router be capable of better that this? I also have one wireless range extender http://www.netgear.co.uk/home/products/wireless-range-extenders/WN3000RP.aspx to try and boost the wireless range to the upstairs bedrooms.
Firstly
Secondly
Message 1 of 8
(2,251 Views)
7 REPLIES 7
Re: New Fibre Installation - Speed away from router
04-04-2013 9:15 AM
I don't know about home plugs but with wireless I upgraded my laptop I put in a different wifi card and an extra antenna and I get 73 mb around most of the house. The other laptops are standard and usually get around 50mb. iPhone gets around 30-40 you won't get full speed with phones or tablets because of the wifi inside them is not up to the job.
Also didn't use the plusnet router from the start bought a asus rt- n66u which has a beast of a wireless range
Just a couple ideas what I did, you will get better replies about home plugs and the plusnet router
Message 2 of 8
(990 Views)
05-04-2013 9:38 AM
Re the homeplugs I'd imagine they should be adequate. If possible I'd try connecting a PC (assuming you have one) directly to the router via ethernet and see how the speeds compare.
Re wireless the router should be capable of the speeds you mention but it's likely the speeds may be a little lower than if you were connected via ethernet or powerline adapters.
Message 3 of 8
(990 Views)
05-04-2013 10:01 AM
I wouldn't expect 85Mbps Homeplugs to be adequate for an FTTC user!
Also try reading the original post properly Adam!
Quote from: carlwalters I ran the recommended BT speed test http://speedtest.btwholesale.com/ while plugged straight into the new router and the DL speeds were about 72Mbps which is great
Message 4 of 8
(990 Views)
05-04-2013 11:31 AM
Message 5 of 8
(990 Views)
06-04-2013 6:02 PM
20mbps is pretty good out of 85mbps home plug adapters.
I've only ever seen about 32 out of my 200s.
Bought some 500s today and they jump between 86 and 109 with an average of 94mbps over 30 seconds.
£39.99 for a pain from PcWorld.
Message 6 of 8
(990 Views)
06-04-2013 6:10 PM
I've just retired my Solwise 85Mbps homeplugs as they where limiting my internet speed to around 13 meg.
I just bite the bullet & ran a cat 5e cable between router downstairs & pc upstairs.
Message 7 of 8
(990 Views)
06-04-2013 6:53 PM
The 582n is the subject of many complaints on here because of its poor wireless speeds. I replaced mine with a superb Asus RT-N56U, it doubled my speeds immediately.
Message 8 of 8
(990 Views)
