New Customer Router Not Required
- Re: New Customer Router Not Required
14-01-2021 10:38 AM
I am intending to switch to Plusnet but don't need/want the router as I already have. Can I specify at point of opening contract to decline router? All I need is config settings.
Thanks!
Thanks!
Message 1 of 3
(592 Views)
2 REPLIES 2
14-01-2021 10:58 AM
I can't be 100% certain here, but I think the default these days is specifying than you want a router at point of order.
For the config settings see HERE
Message 2 of 3
(585 Views)
14-01-2021 11:22 AM
I believe some settings on the router are 'hard wired' so that you are not able to change them as you would be able to do on your own router. Speak to technical services first as they should understand your request and offer you best help whereas sales personnel may not.
Good luck and welcome to the brand!
Message 3 of 3
(578 Views)
