New Customer Fibre wrong speed
- New Customer Fibre wrong speed
22-01-2013 9:25 AM
My fibre unlimited is due to be installed today my line has been activated i am on 40/10 connection too i was given the estimate of 58.1 Mbps please can someone put that right
Sharaz
Sharaz
Message 1 of 9
(1,801 Views)
8 REPLIES 8
Re: New Customer Fibre wrong speed
22-01-2013 11:45 AM
Hi Sharaz,
As soon as your order is complete I'll place a modify order to move you higher to the correct product, this will complete tomorrow for you.
Message 2 of 9
(881 Views)
22-01-2013 1:13 PM
Quote from: Sharaz21 My fibre unlimited is due to be installed today my line has been activated i am on 40/10 connection too i was given the estimate of 58.1 Mbps please can someone put that right
Sharaz
I had the same issue last week - based upon my original post too there seem to be a number of others in a similar position to us. I got switched on to the new product at the weekend but my speed is still not right - i've had to raise another fault to try and get my IP Profile corrected - looks like an issue the BT side. Initially the response was quite quick but it has taken a while to get this bit sorted - so frustrating!
When you do switch my advice would be to make sure you test it - you may get the same issue as me 😞
Good Luck
Message 3 of 9
(881 Views)
22-01-2013 2:52 PM
@Macgoober
Sorry for the wait, we're currently investigating the cause of this and we'll update you shortly.
Message 4 of 9
(881 Views)
22-01-2013 6:48 PM
Sharaz
same issue with me i got my fiber on Friday and getting 40/20 when i should get 80/20 was tested by the engineer and my socket and it read 80/20 after connecting my router and doing speed test iam only getting 36-37/15. how do i sort this out
Message 5 of 9
(881 Views)
22-01-2013 6:51 PM
You don't have the same issue - there is no product 40/20 - please reply to me in your other post
Message 6 of 9
(881 Views)
23-01-2013 11:43 AM
Hi Sharaz,
You're on the higher product now, let me know how you're getting on.
Message 7 of 9
(881 Views)
23-01-2013 4:00 PM
Quote from: chrispurvey Hi Sharaz,
It is working great now i was not expecting the speed to be that high i am getting 9Mb Download speed.
Message 8 of 9
(881 Views)
23-01-2013 4:40 PM
Message 9 of 9
(881 Views)
