New ADSL 2+ Router Sought
- New ADSL 2+ Router Sought
06-09-2009 11:06 PM
Re: New ADSL 2+ Router Sought
07-09-2009 8:41 AM
07-09-2009 9:23 AM
Thanks again.
07-09-2009 9:57 AM
The one thing I have found useful with the Netgear is you can use the RouterStats software from http://www.vwlowen.co.uk/internet/files.htm which allow you to graph the SNR and other elements over time to find out stuff about your line. I am not yet on ADSL2+ but hopefully will be switched soon as I am currently having problems on DSL MAX which the RouterStats software has enabled me to pass on details to PlusNet which otherwise would not be available.
07-09-2009 10:05 AM
Before moving house recently sync wasn't an issue as I always got the full 8128 as I Iived within spitting distance of the exchange. Since moving house I am now on a fairly long line (the line checker said it would only give 512k at best). Initially I could only get the router to sync at about 1200 or so I installed firmware with modem code E.67.2.55 from here which now allows me to sync at between 2500 and 3000. The firmware contains different modem code tailored for ADSL Max on long lines.
Edit: Release notes showing alternative firmware for sync issues.
07-09-2009 10:08 AM
Paul, intersting - I'll let my friend know. I used t ouse a 2200USB and had a 2600G for work, so I know Draytek quite well but as you say £240.00 for a router - ouch.
07-09-2009 10:13 AM
11-09-2009 9:16 AM
I may try the alternative firmware... just wanted to know what model you had in the 2800 series?
11-09-2009 10:19 AM
I thought about changing router but I need the functionality that the 2800 offers (LAN to LAN VPN etc.) and there's not much else out there that offers what the Draytek's do (at their price point)!
Edit: From the release notes for the 2820 firmware:
" For best line compatibility you may also try alternative modem codes. Please let us know your results.
Download from : ftp://ftp.draytek.com/Vigor2820/Firmware "
11-09-2009 11:26 AM
For talkcomp --- still looks like one Draytek router or another is your best bet.
11-09-2009 11:46 AM
Then you could just get a separate Wireless access point for your Wifi(N) requirements http://www.broadbandbuyer.co.uk/Shop/ShopSearch.asp?CategoryID=416
06-10-2009 3:23 PM
I used to get 7.3 - 8Mbps on ADSL MAX but since going ADSL2+ I'm still only getting 7.3 - 8Mbps, although my upload has hit 1Mbps.
The Draytek does seem to sync at a lower speed than other Routers I've tried previously, noticeably my old Netgear DG834GT.
The Wireless on the 2820 is a bit flaky if you use DHCP.
Seems much better if you give your clients static IPs.
As mentioned previously, the Netgear isn't a VPN endpoint, it only supports passthrough.
The Draytek is probably the best you can get for the money in terms of functionality, if you can get over it's little quirks!!
07-10-2009 9:27 AM
Quote from: Sadamski As mentioned previously, the Netgear isn't a VPN endpoint, it only supports passthrough.
Not true for the DG834 which Netgear claims supports up to 5 IPSEC endpoints. However, I've not tried one in anger so I've no idea what the performance is like.
07-10-2009 12:50 PM
The Drayteks support several flavours of VPN and both LAN to LAN and remote teleworker dial-in.
If sync speed is an issue with Draytek's ADSL routers another way to do things is to buy something like the Vigor 2910 (which has an ethernet port for WAN access) and use an ethernet modem (such as this Netgear) or even an existing ADSL router set to "pure bridge" or "fully bridged" mode (in which case it simply acts as a modem).
The login to the ISP is handled by the Draytek whilst the modem or router (in bridge mode) handles the sync with the exchange etc. (see Draytek's own info here - this is written for their own ethernet modem the Vigor 120 but it works just as well for any other.)
07-10-2009 9:34 PM
B.
