New 802.11n Router
- New 802.11n Router
New 802.11n Router
06-09-2010 11:23 PM
Quick question as I might be in the market to buy a new one as I do suffer from poor wifi reception in my house with the current thomson 585 v7.
I am looking to purchase an ADSL Router with teh above spec as I want to be able to stream medie from the PC to my Xbox. I looked at homeplugs as an alterbative but they are not compatible with media extender without a regedit
I think I am on ADSL2 but cant remember - i so is there anything specific I need to look out for in terms of purchasing a new router?
KWack
KWack
Message 1 of 4
(1,024 Views)
3 REPLIES 3
Re: New 802.11n Router
06-09-2010 11:30 PM
[quote=kwack]I looked at homeplugs as an alterbative but they are not compatible with media extender without a regedit
What does this mean ?
If you can get two devices to communicate using an ethernet cable, then the avEasy homeplugs simply replace the ethernet using the mains wiring. No software configuration required.
Message 2 of 4
(458 Views)
07-09-2010 12:07 PM
There was an article on FAQ on a homeplugs page somewhere that said that the following;
Apparently Homplug works with IGMP V2 whereas windows extender uses IGMP V3 and woudl require a windows registry edit to resolve
So am not too keen on messing around with windows registry
Any recommendations for an ADSL2 modem 802.11n router?
Kwack
Kwack
Message 3 of 4
(458 Views)
07-09-2010 8:19 PM
Buy yourself a BT Home Hub V2.0 (the Curved Black one) off eBay for a tenner.
They work perfectly on a PlusNet line and support ADSL2+ .... and the Wireless is 802.11n.
Message 4 of 4
(458 Views)
