New 20CN IP Profile Trial?
- Re: New 20CN IP Profile Trial?
30-10-2011 8:15 AM
Whenever I sync now the IP profile immediately changes to the sync I am at. I am not on a 21CN exchange and the profile is not 88.2% of the sync. Has anybody else seen this?
Message 1 of 6
(1,033 Views)
5 REPLIES 5
30-10-2011 2:36 PM
No new profiles here
Can you screenshot your BT Tester results?
Alex
Alex
Message 2 of 6
(509 Views)
30-10-2011 2:49 PM
The profiles are the same but they change immediately after sync.
Message 3 of 6
(509 Views)
30-10-2011 2:54 PM
Quote from: sjrinfroyle the IP profile immediately changes to the sync I am at.
I mis-read your post - I thought you meant that the IP Profile matches the sync speed.
And I think (although I can't be certain) that I saw what you mention happen a week ago. Maybe they're testing it out?
Alex
Message 4 of 6
(509 Views)
30-10-2011 2:56 PM
Perhaps, here are the results anyway:
Download speedachieved during the test was - 3217 Kbps
Additional Information:
Your DSL Connection Rate :7456 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
Message 5 of 6
(509 Views)
30-10-2011 3:45 PM
Still the same BT IP Profile xxxx as far as I can see, so will have to wait a while for it to increase to match the new sync rate.
Message 6 of 6
(509 Views)
