Network Connectivity ADSL service status
- Network Connectivity ADSL service status
24-11-2009 7:45 PM
I am getting slow speeds again, since about 17:00 this evening, it has dropped by 50% since this mornings checks.
Having checked the "service status" messages, the last one was dated 20/11/2009 which said work had been done on some re-wiring and as a consequence, speeds during the evening would improve... also it appears they were so pleased that everything was working properly they reverted to "Plan A working" for the weekend,
and a proviso...
however, today is Tuesday 24/11/2009, and no update has been posted, nor any reasons given for slow speeds this evening... ?
comments and excuses please
EDIT
I am on pcl-ag04
and a proviso...
We will remain operating under 'Plan A' over the weekend and will review the situation again on Monday when we will provide another update.
EDIT
I am on pcl-ag04
Message 1 of 7
(1,610 Views)
6 REPLIES 6
Re: Network Connectivity ADSL service status
24-11-2009 8:30 PM
Just thought I`d add some more grist to the mill
Sunday BT speed test result...
14:53 Sunday 22 Nove
Download Speed
850 Kbps
0 Kbps 1000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 850 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :1344 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1000 Kbps
My router stats..... Same time sunday...
Downstream Upstream
Rate (Kbps): 1344 448
SNR Margin (dB): 9.3 20.0
Attenuation (dB): 63.5 25.5
Output Power (dBm): 12.1 18.4
Current router stats @ 20:20 24th November 2009
Downstream Upstream
Rate (Kbps): 1856 448
SNR Margin (dB): 5.3 19.0
Output Power (dBm): 11.9 18.7
(N.B. the SNR figure dropped dramatically yesterday afternoon from 9.3 to 5.8 resulting in the increased "Downstream " figure...)
My broadband speed test results,
Date Download Speed Upload Speed
Today 20:26 585 kbps (73.1kB/s) 295 kbps (36.9kB/s)
Today 20:15 385 kbps (48.1kB/s) 375 kbps (46.9kB/s)
Today 19:50 602 kbps (75.3kB/s) 372 kbps (46.5kB/s)
Today 19:36 469 kbps (58.6kB/s) 360 kbps (45kB/s)
Today 18:50 558 kbps (69.8kB/s) 358 kbps (44.8kB/s)
Today 18:29 510 kbps (63.8kB/s) 376 kbps (47kB/s)
Today 18:19 469 kbps (58.6kB/s) 371 kbps (46.4kB/s)
Today 18:18 478 kbps (59.8kB/s) 369 kbps (46.1kB/s)
Today 17:57 640 kbps (80kB/s) 371 kbps (46.4kB/s)
Today 17:09 426 kbps (53.3kB/s) 372 kbps (46.5kB/s)
Today 17:08 522 kbps (65.3kB/s) 373 kbps (46.6kB/s)
By the way.... I am running Router Stats, and have graphs for the past 48 hours.
Download Speed
850 Kbps
0 Kbps 1000 Kbps
Downstream Upstream
Downstream Upstream
Message 2 of 7
(716 Views)
24-11-2009 8:36 PM
Quote from: shutter however, today is Tuesday 24/11/2009, and no update has been posted, nor any reasons given for slow speeds this evening... ?
Apart from the one Posted on: Tuesday 24 November 2009, 20:10 - 20 minutes before your second post.
Message 3 of 7
(716 Views)
24-11-2009 8:39 PM
Which I have just seen and noted..... not much good putting "sorry :'(" after the last couple of weeks problems which were supposed to have been sorted out.
Will we be only paying half (or even less) this month because we are all getting only half the speed we normally get...... I doubt it...
just done a speed check.... my line is rated at 1.8m look at this....
Today 20:40 341 kbps (42.6kB/s) 280 kbps (35kB/s)
Message 4 of 7
(716 Views)
24-11-2009 8:41 PM
http://portal.plus.net/support/service/problems/problem.php?intProblemId=59438
Message 5 of 7
(716 Views)
24-11-2009 8:41 PM
I'll post the update to the main Network Capacity thread now. I would have done this earlier had the more recent problem not reared its head
Edit: now posted, I need to dash for a train now guys but will try and pop back in here when I get back home (and will keep an eye on things from my mobile).
Message 6 of 7
(716 Views)
24-11-2009 9:03 PM
Thanks Bob.... have a safe journey home... get some rest, and come back tomorrow to sort it all out.
Message 7 of 7
(716 Views)
