Netgear Router
- Re: Netgear Router
Netgear Router
25-12-2013 3:20 PM
Netgear DGN2200 Wireless-N300 ADSL Modem Router
I bought this for my adsl connection for the QoS that the plusnet router doesnt offer yet I connected it today and the internet light is solid red which means it hasnt got a connection. I have put my plusnet login details in and left the rest of the router settings default from netgear is there anything else I should change as it is quite frustrating to use the router given to me from plusnet
Message 1 of 7
(2,474 Views)
6 REPLIES 6
Re: Netgear Router
25-12-2013 3:37 PM
Check your adsl settings, can't remember off the top of my head what they are, check the library for generic settings.
Also make sure your user name is @plusdsl.net
Then check the log to see if the error is dsl or authentication related.
Message 2 of 7
(1,587 Views)
Re: Netgear Router
25-12-2013 3:43 PM
Sorry to be a noob but where do I find the library? And where can I see the log?
Message 3 of 7
(1,587 Views)
Re: Netgear Router
25-12-2013 4:22 PM
ADSL Settings?
Message 4 of 7
(1,587 Views)
Re: Netgear Router
25-12-2013 4:40 PM
Hm I will check this. In regards to the DNS stuff should that be preset or allow the router to do it by default?
Message 5 of 7
(1,587 Views)
Re: Netgear Router
25-12-2013 4:46 PM
Quote from: Jakeh1990 Sorry to be a noob but where do I find the library? And where can I see the log?
Library look at the top of the screen next to the Forums link.
Log is on the router web page, somewhere there will be a link to a log.
Message 6 of 7
(1,587 Views)
Re: Netgear Router
25-12-2013 5:09 PM
Quote from: Jakeh1990 Netgear DGN2200 Wireless-N300 ADSL Modem Router
Have you tried the Auto setup wizard
Auto-Detect Connection Type
This Setup Wizard can Detect the type of Internet Connection you have.
Do You Want The Smart Setup Wizard To Try And Detect The Connection Type Now?
Main settings are
ADSL Settings
Multiplexing Method VC BASED
VPI 0
VCI 38
Basic Settings
Does Your Internet Connection Require A Login? > Yes
Internet IP Address > Get Dynamically From ISP
Domain Name Server (DNS) Address > Get Automatically From ISP
NAT (Network Address Translation > Enable
Advanced ADSL Settings
Advanced ADSL settings
Modulation mode MultiMode > Tick listed below, untick the rest
ADSL2 (G.992.3)
ADSL2+ (G.992.5)
Reach Ext. ADSL (Annex L)
Double Upstream (Annex M
Don't forget to click Apply to make the changes permanent
Message 7 of 7
(1,587 Views)
