Netgear Router Rebooting Frequently
- Netgear Router Rebooting Frequently
06-11-2012 1:58 PM
Hi All,
Since we returned from holiday last week; I have noticed that our router now seems to keep rebooting itself at varying intervals (anything from 15 minutes to 2 hours between reboots).
The router is a Netgear DGN2200v3.
The logfile from the router since the last known reboot is shown
Apart from the DoS attacks; which I believe are quite common & the router is blocking them; does anybody have any ideas? My searching on the internet has not given me much to go on.
It appears that the day before we returned we had a major power outage, the router was on whilst we were away as we have a couple of IP-cams to keep an eye on our cats with, but I wouldn't have thought that such an outage would have had much effect?
Quote [DoS attack: ACK Scan] from source: 158.58.172.248:8090, Tuesday, November 06,2012 12:59:57
[email sent to: email@email.com] Tuesday, November 06,2012 12:00:02
[Time synchronized with NTP server time-g.netgear.com] Tuesday, November 06,2012 11:45:16
[Internet connected] IP address: xx.yyy.zzz.www, Tuesday, November 06,2012 11:42:38
[DSL: Up] Tuesday, November 06,2012 11:42:33
[USB device attached] The USB storage device <10EADS External> (<Elements>) is attache, Tuesday, November 06,2012 11:42:21
[DHCP IP: (192.168.0.3)] to MAC address 00:0E:58:4F:7A:82, Tuesday, November 06,2012 11:41:49
[Initialized, firmware version: V1.1.00.10_1.00.10 ] Tuesday, November 06,2012 11:41:34
Message 1 of 2
(1,294 Views)
1 REPLY 1
Re: Netgear Router Rebooting Frequently
06-11-2012 2:27 PM
A router that frequently suffers spontaneous reboots is usually faulty. You could try resetting the router to factory settings - but if you do that you'll have to set it up again from scratch.
Message 2 of 2
(559 Views)
