Netgear Nighthawk or Linksys WRT1900AC?
Lucas712
I've been looking around for a new router (again) to replace the HUB One I currently have.
Out of the two in the subject which would be better and would I have to use the BT Openreach box for them?
I'm also wondering whether they are "over-the-top" for the package I am currently on? (Fibre Plus package).
4 REPLIES 4
Mustrum
Fixes: 77
Re: Netgear Nighthawk or Linksys WRT1900AC?
Much will depend on your needs, but you also need to look a stage further. Netgear for example have further model designations, the R7000 would need a modem, but for around £10 more they also do the D7000 which has a built in VDSL modem .Linksys are the same.
hitchhiker43
Fixes: 4
For your own sake when things go wrong I would limit your choice to one that has proper telnet diagnostic reporting facilities such as those listed at this site DSLSTATS pretty routers with no diagnostics are worthless IMOP
Tp-link W8960n on longgggggggg line!
Lucas712
It will need to support multiple devices at once (approx. 5).
markhawkin
Fixes: 12
@Lucas712
What aspect or aspects of your current router are you dissatisfied with ?
