Need someone to look over router stats please.
- Need someone to look over router stats please.
26-02-2013 8:28 PM
DSL Connection
Link Information
Uptime:
0 days, 0:29:05
DSL Type:
G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,132 / 14,916
1,133 / 13,802
Data Transferred (Sent/Received) [MB/MB]:
4.99 / 39.71
Output Power (Up/Down) [dBm]:
12.5 / 20.0
Line Attenuation (Up/Down) [dB]:
15.5 / 29.5
SN Margin (Up/Down) [dB]:
6.0 / 3.0
Vendor ID (Local/Remote):
TMMB / IFTN
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
0 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
Error Seconds (Local/Remote):
1 / 0
FEC Errors (Up/Down):
17,888 / 1,422,486
CRC Errors (Up/Down):
1,281 / 129
HEC Errors (Up/Down):
0 / 609
Could someone have a quick look at the above please i am struggling to stream anything and gaming and teamspeak is a nightmare. I am connected directly to the router and into the master second(behind that plate).
Re: Need someone to look over router stats please.
26-02-2013 9:49 PM
I'm no expert, though I have had a lot of experience in monitoring stats. The HEC error rate shown above is about one per 3 seconds of 'up time'. I suggest that you do a BT speed test (see the sticky posts at the top of this forum) and post the
Cheers,
Kevin
26-02-2013 10:08 PM
those stats don't look too bad. You may have a bit of noise present as there's a few CRC errors there, but I don't think that has anything to do with your problems which I think are much more related to the Network issues http://community.plus.net/forum/index.php/topic,111170.0.html
Read a bit and then jump to the last few pages to see a more up to date situation. Some are having problems tonight and some aren't.
26-02-2013 10:17 PM
27-02-2013 12:13 AM
27-02-2013 12:23 AM
Rather than restarting the Modem/Router which causes you a loss of sync, better to log into it and Disconnect/drop your PPP(oA) Internet session, pause 30 seconds and then click Connect. This will Gateway hop, and you may get on a Gateway not displaying the problem (at the time).
Edit: If you are able to post some stats from the middle of the day that may be useful.
