Need Good ADSL2 Bridge
franklinomiller
Folks,   don't need a router/gateway, just a good solid ADSL2 bridge to run with my account.    Any ideas on what to recommend.    I have plume (www.plume.com) ... in order to not do double NAT (and most home routers (e.g. sky) are utter rubbish) it's best to just use a bridge.
F
2 REPLIES 2
mikelahey
Fixes: 12
Re: Need Good ADSL2 Bridge
Second hand unlocked Openreach Huaewei HG612 VDSL modem is the cheapest option, once unlocked it can be re-configured to work with ADSL2. You can pick up a locked one off a well known auction site for around £15, the unlocked ones tend to be a bit dearer.
The unlocking procedure is fairly straight forward and is purely software based so you don't need to open it up or do any soldering.
https://kitz.co.uk/routers/hg612unlock.htm
The other option is something like a Draytek vigor 130 - https://www.draytek.co.uk/products/business/vigor-130 which is a dedicated VDSL / ADSL modem for about £80.
Some combined modem / routers can also run in bridge mode, for example the Zyxel VMG8924-B10A can be used as a bridge as well as a modem as can many other consumer routers made by other manufacturers.
Fixes: 399
@franklinomiller if you're anywhere near the South Cheshire area , I've got 2 or 3 old 2700HGVs (Aka BT Business HUB) that are surplus to requirements. In their day they were noted as having one of the best performing ADSL2 modem around. I believe they can be set to bridge mode.
You're welcome to them if you can take them away...
