NI-specific IP address for RTE Player?
iambatman
I can't access RTE player as my ip is based in england, can I get issued a northern ireland specific ip address if I add a static ip address to my account?
Fixes: 188
Re: NI-specific IP address for RTE Player?
I'm currently watching a program about extreme commuters on RTÉ Player. I live in Sheffield.
Have you tried dropping and re-establishing your PPP session?
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
Fixes: 4
RTÉ Player is working on my static IP address in Essex !
There are some interesting programs there, I will have to visit the site more often  Smiley
http://www.rte.ie/player/#
Fixes: 21
Works in Gloucestershire, 20CN exchange, Gateway ptn-ag03.
Fixes: 167
If you can log in to our website and open a support ticket FAO: Bob Pullen we'll pick it up.
 Chris Parr
 Plusnet Staff
Robin says, you are probably on a IP address that isn't being picked up as UK when it should.  PN has a few of those at the moment, a router reboot can help to get a new IP adress if you have a dynamic IP.  But don't do that too many times or BT will cripple your speeds.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 21
[pedant mode]
You shouldn't reboot, you lose sync with the exchange, you should Gateway hop by Disconnecting your PPP Internet session and then Connecting again by logging into your modem/router Internet Interface.
[/pedant mode]
Fixes: 10
I don't know why you put the [pedant mode] markers - it is very sensible advice!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 106
@iambatman, as mentioned by Chris - If you raise a support ticket for my attention I will get this sorted for you without you having to gateway hop.
