My router has gone - can I get a replacement
- My router has gone - can I get a replacement
02-11-2011 11:35 AM
Many thanks,
Alex
Re: My router has gone - can I get a replacement
02-11-2011 11:49 AM
Unfortunately the warranty on your router expired back in August. However we're happy to offer you another router on a 12 month deferred contract. We'd just ask you to pay £4.99 for postage and packing. Is that OK?
02-11-2011 12:14 PM
Thanks,
Alex
02-11-2011 1:18 PM
02-11-2011 1:32 PM
Thanks,
Alex
dick:quote
02-11-2011 2:42 PM
To clarify we only take monthly subscription payments from direct debits and we ask that any one-off payments are taken via card.
I've ordered your router which should be with you in around 3 working days.
Just out of curiosity can you let me know what signs the router has shown that it's faulty? I.e is it not powering up at all, are some lights on but not others etc...
02-11-2011 4:24 PM
Quote from: _Adam_Walker_ Thanks,
"No response from Plusnet" on my mobile and they became more frequent. Then the Internet light was off intemittently and finally off all the time. I had an nasty Trojan and viral infection 2 days ago - Win32.Ramnit.Gen3 and Trojan.Win32.Vundo - which partially damaged my system. I don't know if this also damaged the router or if the router packing up was coincidental, but it certainly added to the confusion.
Thanks again,
Alex
02-11-2011 4:33 PM
My advice would be to give the new router a try when it arrives and if there is no change to raise a fault here: https://portal.plus.net/apps/kbdfaults
05-11-2011 12:14 AM
New router arrived today and it is working OK.
Many thanks,
Alex
07-11-2011 1:15 PM
