My estimated speed
- My estimated speed
My estimated speed
14-05-2013 10:22 AM
I would appreciate it if somebody could look into this matter as the estimated speed is one of the main reasons I switched from talktalk.
Many thanks.
Re: My estimated speed
14-05-2013 10:28 AM
Could you do a BT speed test at http://speedtest.btwholesale.com, click on 'Further Diagnostics', run that part and post the results.
Also what does this say https://portal.plus.net/my.html?action=data_transfer_speed
Are you connected wired or wireless to your router?
14-05-2013 11:34 AM
This is my data transfer speed
Estimated line speed:
12Mb (This may vary between 10Mb and 13.5Mb) - Checked on 2013-04-02 20:50:55
Current line speed:
4.2 Mb
These are the results from bt
1. Best Effort Test: -provides background information.
Download Speed
4.31 Mbps
0 Mbps 4 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.31 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4.12 Mbps
Upload Speed
0.37 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.37Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
I am using a wired connection on my router.
14-05-2013 12:00 PM
I've just been running some line diagnostics and I'm unable to see any obvious problems from the results.
I'm wondering if you're phone socket is the type that has a test socket that you could connect the router to? http://www.plus.net/support/broadband/master-socket-guide.shtml
If so I'd like to run another test with the router in there to see if there's a difference in the results.
Adam
14-05-2013 12:25 PM
14-05-2013 12:30 PM
14-05-2013 1:33 PM
23-05-2013 11:27 AM
23-05-2013 2:34 PM
I've checked your connection and can see there has been an increase so I've changed your speeds profile to 7Mb/s.
I've also noticed that you have frequent disconnections shortly after midnight regularly;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13693158263849.png"/>
Is there anything that happens at this time?
It will also be worth us placing a SNR reset on your line which should increase your speeds further, we just need to make sure there your line is stable over the next 24 hours first.
23-05-2013 2:52 PM
23-05-2013 5:09 PM
23-05-2013 7:58 PM
24-05-2013 9:15 AM
24-05-2013 4:15 PM
Quote from: adisenoj1974 We do have a sky box plugged into the line.
Is that plugged in to an ADSL filter?
