My disconnects
- Re: My disconnects
- « Previous
- Next »
Re: My disconnects
04-04-2011 10:45 AM
Hi Lucerne,
It should be fine - even if the fault is referred back voice faults always take precedence so nothing will interfere with the fix. Speaking of which, have you had any updates since the stated date of the 31st on that?
Message 46 of 54
(426 Views)
Re: My disconnects
04-04-2011 11:54 AM
Thanks Matt! nothing more I'm afraid.
Is it the permissions from council or occupier outside which hole needs digging, that could be delay. Spot is on path not blocking entrances.
Message 47 of 54
(426 Views)
Re: My disconnects
05-04-2011 9:28 AM
It's a lovely rainy morning and the contractors are digging their hole!
Almost simultaneously I get a support email that they have asked for interleaving to be turned on! Don't they know that there is an ongoing voice fault to blame for the instability?
Why not wait for that to be fixed first!?
Message 48 of 54
(426 Views)
Re: My disconnects
06-04-2011 7:06 AM
Whaaaaaa....They are coming thsi morning to test that my wiring isn't to blame, got cost warning, They've already tested it
Edit
Another very pleasant engineer has found that the actual location is by a neighbour's drive, so X marks another hole to be dug. There are a number of spare pairs ( hurrah), but they all test faulty (boo) .
Edit
Message 49 of 54
(426 Views)
Re: My disconnects
07-04-2011 5:46 PM
All sorted
One wire nearly broken and water around; joint made and sealed. Holes filled in between ~9.45 and ~3.30.
Sync seems much better.
Is it worth, or better not, executing around midday resyncs?
How long before noise margin winds down to target 6?
Message 50 of 54
(426 Views)
Re: My disconnects
08-04-2011 8:49 AM
HI lucerne,
I'll run a few checks and see what I can come up with.
Jojo
Jojo
Message 51 of 54
(426 Views)
Re: My disconnects
08-04-2011 9:13 AM
Hi lucerne,
Line is solid since yesterday afternoon so I've reset the SNR. I'll check in a bit to see when it's taken effect.
Jojo
Jojo
Message 52 of 54
(426 Views)
Re: My disconnects
08-04-2011 9:35 AM
Now 6.5db and 6983 kbps and 46.5dB attenuation.
Thanks Jojo.
Thanks Jojo.
Message 53 of 54
(426 Views)
Re: My disconnects
08-04-2011 10:42 AM
HI lucerne,
Your profile's back up to 6000k and I've changed that on our system so you should see that within the next 15 minutes.
Jojo
Jojo
Message 54 of 54
(426 Views)
- « Previous
- Next »
