My bro now on the trial but massive FEC/CRC errors
- Re: My bro now on the trial but massive FEC/CRC er...
29-09-2009 7:23 PM
Plusnet Thomson TG585 stats as below. It was originally on G.992.3 Annex A but I telnetted in and forced the adsl2+ mode.
Any ideas?
Link Information
Uptime: 0 days, 0:26:40
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 827 / 1,969
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 29.5 / 59.5
SN Margin (Up/Down) [dB]: 6.0 / 6.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,232 / 7,001
CRC Errors (Up/Down): 4,294,967,232 / 7
HEC Errors (Up/Down):
Any ideas?
Link Information
Message 1 of 9
(1,838 Views)
8 REPLIES 8
Re: My bro now on the trial but massive FEC/CRC errors
29-09-2009 7:28 PM
At that sync rate an atten the dlm dosent allow the + to be used. if no tones above 1.1khz are used then its a adsl2 sync
Maybe try and telnet in to use adsl2 and not adsl2+. doubt it would make a diffrence thoe as the dlm overrides my dg834g v4 if i try to force a + sync.
Message 2 of 9
(831 Views)
29-09-2009 7:51 PM
Yeah I thought that, will put it to 2 and then check the stats....
Message 3 of 9
(831 Views)
29-09-2009 8:15 PM
Quote from: tallcal
Those high up direction counts look totally bogus to be honest. Do they appear like that immediately after a reboot or do they increment from zero?
Message 4 of 9
(831 Views)
30-09-2009 12:06 PM
Compute 2^32 - 1
Message 5 of 9
(831 Views)
30-09-2009 8:29 PM
Quote from: MrC
Quote from: tallcal
They increment from zero.... here are the stats after I put it back to 992.3
Link Information
Uptime: 1 day, 0:36:59
DSL Type: G.992.3 annex A
Bandwidth (Up/Down) [kbps/kbps]: 808 / 1,994
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 29.5 / 56.0
SN Margin (Up/Down) [dB]: 6.0 / 7.0
FEC Errors (Up/Down): 2 / 117,173
CRC Errors (Up/Down): 2 / 76
HEC Errors (Up/Down): 1 / 65
Message 6 of 9
(831 Views)
30-09-2009 9:55 PM
Ah that looks better
To be honest your downstream error counts look fairly reasonable considering the sync rate, line attenuation and SNR margin.
Message 7 of 9
(831 Views)
01-10-2009 2:14 AM
drop in your attention as well when using 992.3
Message 8 of 9
(831 Views)
02-10-2009 11:30 AM
thanks for the feedback guys
Message 9 of 9
(831 Views)
