My Websites Being Blocked By Plusnet
- My Websites Being Blocked By Plusnet
- « Previous
- 1
- 2
- Next »
Re: My Websites Being Blocked By Plusnet
15-01-2014 9:12 AM
Fixed.
A configuration option caused hostgators dns server addresses to be falsely marked as private, and so caused it to fail validation.
Amended the configuration, and now queries on the affected servers work:
# dig www.overseas-holiday-rentals.com
; <<>> DiG 9.7.3 <<>> www.overseas-holiday-rentals.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8940
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 2, ADDITIONAL: 0
;; QUESTION SECTION:
;www.overseas-holiday-rentals.com. IN A
;; ANSWER SECTION:
www.overseas-holiday-rentals.com. 13987 IN CNAME overseas-holiday-rentals.com.
overseas-holiday-rentals.com. 13987 IN A 192.254.189.239
;; AUTHORITY SECTION:
overseas-holiday-rentals.com. 85987 IN NS ns368.hostgator.com.
overseas-holiday-rentals.com. 85987 IN NS ns367.hostgator.com.
;; Query time: 0 msec
;; SERVER: 84.93.210.13#53(84.93.210.13)
;; WHEN: Wed Jan 15 09:11:26 2014
;; MSG SIZE rcvd: 130
Cheers,
Chris
;; Got answer:
;; ANSWER SECTION:
Cheers,
Chris
Message 16 of 22
(470 Views)
15-01-2014 9:19 AM
Something to do with the IP address beginning 192?
Message 17 of 22
(470 Views)
15-01-2014 9:24 AM
Indeed.
Fixed now, so alls well that ends well.
Message 18 of 22
(470 Views)
15-01-2014 10:06 AM
Yep.
I can confirm that my domains are now resolving again on the plusnet dns servers.
probably opening a can of worms here but what are the arguments for either sticking with google/another dns or switching back to plusnet's?
Cheers
Chris
Cheers
Chris
Message 19 of 22
(470 Views)
15-01-2014 10:15 AM
Potentially faster browsing - if the DNS lookups occur quicker using Google's servers. There's a free tool to see which is the fastest global DNS server for you - https://code.google.com/p/namebench/ I don't believe it will check PN's servers however.
There are also advantages with DNS providers like OpenDNS (free), where you can set up content filtering.
Message 20 of 22
(470 Views)
15-01-2014 10:39 AM
Quote from: behaviourneeds probably opening a can of worms here but what are the arguments for either sticking with google/another dns or switching back to plusnet's?
Why not use one of each? That's what I do. Plusnet as primary and Google as a backup.
Message 21 of 22
(470 Views)
15-01-2014 10:48 AM
Due to the way the Plusnet servers are set up there's very little benefit if having two Plusnet servers so Bob's suggestion makes a lot of sense.
Message 22 of 22
(470 Views)
- « Previous
- 1
- 2
- Next »
