My Websites Being Blocked By Plusnet
Angry I cannot access my own web sites hosted on Hostgator from my Plusnet broadband unless I use a VPN.
Server not found
Firefox can't find the server at www.overseas-holiday-rentals.com.
    Check the address for typing errors such as ww.example.com instead of www.example.com
    If you are unable to load any pages, check your computer's network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
21 REPLIES 21
Fixes: 62
Re: My Websites Being Blocked By Plusnet
No problem here using Google DNS
No problem here using Plusnets DNS
I think it's the PN DNS servers
PN DNS
; <<>> DiG 9.8.3-P1 <<>> www.overseas-holiday-rentals.com @212.159.13.49
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 12266
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.overseas-holiday-rentals.com. IN A
;; Query time: 415 msec
;; SERVER: 212.159.13.49#53(212.159.13.49)
;; WHEN: Tue Jan 14 16:16:17 2014
;; MSG SIZE  rcvd: 50
OpenDNS
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 20614
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 0
;; ANSWER SECTION:
www.overseas-holiday-rentals.com. 14400 IN CNAME overseas-holiday-rentals.com.
overseas-holiday-rentals.com. 14400 IN A 192.254.189.239
;; Query time: 177 msec
;; SERVER: 2620:0:ccc::2#53(2620:0:ccc::2)
;; WHEN: Tue Jan 14 16:15:58 2014
;; MSG SIZE  rcvd: 80
If you go to 192.254.189.239, the site should be working ok (Edit: Actually, it won't as the hosting site has multiple sites on the same IP). Is this a new site or have you recently changed the DNS records?
Fixes: 10
Confirmed that there is an issue with the Plusnet DNS:
C:\Users\John>nslookup www.overseas-holiday-rentals.com 212.159.6.9
Server:  cdns01.plus.net
Address:  212.159.6.9
DNS request timed out.
   timeout was 2 seconds.
*** Request to cdns01.plus.net timed-out
C:\Users\John>nslookup www.overseas-holiday-rentals.com 8.8.8.8
Server:  google-public-dns-a.google.com
Address:  8.8.8.8
Non-authoritative answer:
Address:  192.254.189.239
Aliases:  www.overseas-holiday-rentals.com
This will identify which DNS server I'm hitting:
C:\Users\John>tracert 212.159.6.9
Tracing route to cdns01.plus.net [212.159.6.9]
over a maximum of 30 hops:
 1     1 ms     1 ms     1 ms  tg582 [192.168.1.254]
 2    23 ms    24 ms   195 ms  lo0-central10.ptn-ag04.plus.net [195.166.128.193]
 3    21 ms    20 ms    20 ms  link-a-central10.ptn-gw01.plus.net [212.159.2.140]
 4    21 ms    20 ms    21 ms  xe-8-2-0.ptw-cr01.plus.net [212.159.0.116]
 5    21 ms    21 ms    23 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
 6    22 ms    24 ms    21 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
 7    21 ms    21 ms    23 ms  cdns01.plus.net [212.159.6.9]
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 10
Quote from: AndyH
That won't actually work because there are multiple websites on the same IP.
http://www.overseas-holiday-rentals.com/:192.254.189.239 will work however
Edit: I didn't spot AndyH had changed his post after I viewed it and before I clicked quote!
DNS Servers not resolving our domains
Hi.
We have a stack domains hosted with hostgator in the USA and they are not resolving from our PlusNet business line - if I change the DNS settings from the standard PlusNet ones to Googles everything is back to normal.
Both Pinging the domains or tracert just times out.
One of the domains is www.behaviourneeds.com - any ideas?
Chris
Re: DNS Servers not resolving our domains
Not just you.  See
http://community.plus.net/forum/index.php/topic,122472.0/topicseen.html
Suggest you post in that thread and ask the mods to lock this one?
Fixes: 62
To save you the trouble I have merged them
Thanks very much...
Didn't even notice this post.
Chris
Fixes: 10
Quote from: TORPC
Which gateway are you on?
Legend
Fixes: 168
Matt's heading to speak to the networks guys now about this.
Fixes: 10
Put the IP address 192.254.189.239 in to http://www.yougetsignal.com/tools/web-sites-on-web-server/ and you'll get a list of other websites that are probably not working.
Fixes: 142
Failing for me at home connecting to a DNS server in Telehouse North:
nslookup overseas-holiday-rentals.com 212.159.6.10
Server:  cdns02.plus.net
Address:  212.159.6.10
*** Request to cdns02.plus.net timed-out
Tracing route to cdns02.plus.net [212.159.6.10]
  1    3 ms    3 ms    3 ms  home.gateway [192.168.1.254]
  2    17 ms    15 ms    15 ms  lo0-central10.ptn-ag03.plus.net [195.166.128.192
  3    16 ms    15 ms    15 ms  link-a-central10.ptn-gw01.plus.net [212.159.2.13
6]
  4    16 ms    15 ms    15 ms  xe-5-3-0.ptw-cr01.plus.net [212.159.0.108]
  5    16 ms    15 ms    15 ms  te9-4.ptn-gw01.plus.net [195.166.129.33]
  6    17 ms    16 ms    16 ms  vl55.ptn-lb02.plus.net [212.159.2.125]
  7    16 ms    16 ms    17 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
All OK from the office though, connecting to a DNS server in City Lifeline:
  1    16 ms    9 ms    <1 ms  10.3.23.253
  2    <1 ms    <1 ms    <1 ms  10.0.3.17
  3    1 ms    <1 ms    <1 ms  vlan380.pbs-cr01.plus.net [84.93.216.88]
  4    8 ms    8 ms    8 ms  gi6-8.ptp-cr01.plus.net [84.93.216.95]
  5    9 ms    9 ms    9 ms  gi1-22.pcl-gw01.plus.net [84.93.224.49]
  6    9 ms    9 ms    9 ms  vl63.pcl-lb01.plus.net [212.159.2.252]
  7    8 ms    8 ms    9 ms  cdns02.plus.net [212.159.6.10]
Trace complete.
Huh
Thanks all, problem 79179 has been raised, I expect we'll have an update for you tomorrow. Sorry about this.
