My TG582n just got itself in a tizzy after about 46 days running
Pettitto
Fixes: 5
Re: My TG582n just got itself in a tizzy after about 46 days running
I was going to suggest that as an option.
What are the response times like via Telnet?
Oldjim
Resting Legend
Fixes: 63
normally very quick
Fixes: 159
...and at present?
I'm wondering if you try a telnet login if you'll get told that all the sessions are in use.  RS can leave telnet sessions in a bit of a pickle!
Oldjim
Resting Legend
Fixes: 63
nope straight in
That particular problem was fixed some time ago after I reported it on the Routerstats forums
Actually that wasn't a fair test as the warm restart will have cleared everything
Oldjim
Resting Legend
Fixes: 63
Just had another kernel warm restart (much better speed) but it took about 9 minutes to authenticate
Is that my router or did something glitch
Pettitto
Fixes: 5
There was an outage at approximately 1:11pm, which may have affected the authentication side of things?
Oldjim
Resting Legend
Fixes: 63
Exactly when I had the problem
Thanks for the information
HPsauce
Quote from: Chris
Certainly dumped me off for about a quarter of an hour. Refused to authenticate for at least 10 minutes.  Sad
Fixes: 159
Quote from: Oldjim
Hi Jim,
I see those too from time to time.  For no apparent reason the router just decides to up sticks and start again.
have you noted any pattern to this?  So much for you not wanting to bounce your router earlier this week!  Roll_eyes
Kevin
Oldjim
Resting Legend
Fixes: 63
Not really - it seems to be totally random
