My Stable Rate has Collapsed
- My Stable Rate has Collapsed
04-12-2007 4:57 PM
Re: My Stable Rate has Collapsed
04-12-2007 5:01 PM
04-12-2007 5:33 PM
It looks like you may have had a recent blip in your sync speeds, which is now recovering.
I've just manually mapped BTs profile of 1500Kbps against your account, so if you reboot you should see an improvement in speeds.
05-12-2007 10:03 AM
Many thanks. I see I getting 750k this morning.
Jelv - the only factor I an aware of that affects broadband is heavy rain. Ignoring that, I get disconnects (loss of PPP) starting from around 16:30 which can't be anything in my house, or likely nearby. Unfortunately whenever anything goes wrong people start talking about telephone points, other equipment etc. I've had the same configuration for years so I know it can't be me. It must be either BT or Plus that trigger these problems.
05-12-2007 10:05 AM
05-12-2007 10:07 AM
Phil
05-12-2007 12:24 PM
I made a few internal wiring changes but still received a 500Kb connection. I removed a 20 year old phone and now run at 1Mb or 1.5Mb. Maybe the phone started to create more interference or maybe more sensitive equipment was installed downline from me.
It could be worth a look at your wiring and equipment if I had done nothing I would still be running at 500Kb.
13-12-2007 8:31 AM
1) I only have a DECT phone and the modem attached. There is no other wiring
2) It's been up and down for years and I've changed nothing. Same modem, same software, same computer. Changing filters has absolutely zero impact. I can have long periods of quite reasonable performance. Local software and hardware can't account for that.
3) There is nothing I can see in my house or nearby that could correlate with the periods of poor performance. The single exception is heavy rain but that tends to stop ADSL whereas my normal problems are either stable rate or PPP drop-outs.
What I will say is the lower speed has more-or-less eliminated the pattern of PPP drop outs after 16:00 every day but I'd rather stick with that and get a better speed.
13-12-2007 9:27 AM
It looks like you had a bit of a blip as you're now syncing at 2144Kbps again and should see an improvement in profile again in about 48 hours time.
Are you suffering from dropped connections at all? Or is that something that just happens occasionally?
13-12-2007 1:50 PM
The drop outs have disappeared over the last few days so perhaps it's a feature of sync speed rather than exchange congestion etc. It's the PPP connection that stops. The modem claims it still has an ADSL link to the exchange. I don't know what the PPP connection is precisely or what factors encourage it to drop out. I can always reconnect by switching the modem off and on.
14-12-2007 12:44 PM
If you try rebooting your router now, your speeds should be marginally improved.
Glad to hear that there's a some more stability now
16-12-2007 10:31 AM
I've said it before a number of times, Plusnet needs to think about how to offer a better quality service at a higher price. I don't won't bundled phone calls etc. I want a better broadband. As it stands all the telephone line providers offer much the same take-it-or-leave-it flakey product. When is someone (especially those who are actually BT) going think about how to improve quality on older lines like mine? If you're not careful the time will come when you'll start losing customers to cellular and WiMax providers.
17-12-2007 11:54 AM
We're merely offering what is on the market from BT Wholesale. We're essentially reselling their services and providing Customer and Technical Support for our customers (obviously with additional services included).
When BT offer ADSL2+, we'll offer ADSL2+. When BT offer VDSL (amusingly called Very Fast Digital Subscriber Line) we'll offer VDSL. When BT offer FTTH/C, we'll offer that as well.
Please do bear in mind that we are merely a retailer and not a wholesaler.
17-12-2007 11:59 AM
Quote from: Jameseh When BT offer FTTH/C,
I dunno.. I was looking at the prices of the flats above Plusnet Towers. I'm sure you could arrange some sort of FTTFU (Fibre To The Flat Upstairs) for a reasonable price without involving BT ;);)
B.
17-12-2007 12:06 PM
