My ROUTER PAGE wont load up ?? http://192.168.0.1/
- My ROUTER PAGE wont load up ?? http://192.168.0.1/
17-05-2011 11:18 AM
http://192.168.0.1/
any tell me if it is down or summat ?
Message 1 of 6
(3,665 Views)
5 REPLIES 5
Re: My ROUTER PAGE wont load up ?? http://192.168.0.1/
17-05-2011 11:25 AM
It's best to stick to the one thread. What you are trying to access is your Netgear router. If you have it connected to the mains then it is isn't "down". Check for lights on the fascia.
Message 2 of 6
(1,430 Views)
17-05-2011 11:26 AM
If it is down then the problem will be local to your setup and not something we can easily ascertain from this side. I'd try a router reboot if you haven't done so already. Failing that, running the following command from a command line should give us some information to go on.
Is it affecting your actual Internet connectivity?
ipconfig /all
Message 3 of 6
(1,430 Views)
17-05-2011 12:37 PM
Quote from: Bob Is it affecting your actual Internet connectivity?
See djpinky's other thread, here: http://community.plus.net/forum/index.php/topic,95875.0.html
Message 4 of 6
(1,430 Views)
17-05-2011 12:43 PM
Thanks, the solution you've posted over there is exactly what I would have suggested
Message 5 of 6
(1,430 Views)
17-05-2011 12:47 PM
Moderators Note
Thread locked in favour of this one.
Message 6 of 6
(1,430 Views)
