My Opinion
- My Opinion
- « Previous
- Next »
Re: My Opinion
06-05-2009 11:09 PM
Re: My Opinion
06-05-2009 11:15 PM
Re: My Opinion
06-05-2009 11:27 PM
Re: My Opinion
07-05-2009 5:32 PM
I have changed my Router
Re: My Opinion
07-05-2009 6:00 PM
Re: My Opinion
07-05-2009 7:10 PM
conected to the main BT socket was loose, so I have disconected the whole thing all together, so there is no point anymore on me taking pictures of it, as there is no
conection between the two....But yes there is some improvement.
Re: My Opinion
08-05-2009 9:07 PM
Re: My Opinion
09-05-2009 11:54 AM
ADSL Internet Settings
Downstream Upstream
1856 448
Noise margin
9.6 12.0
Output power
16.9 12.4
Attenuation
63.0 31.5
The noise it's still high, cos I am sure I have seen it on 7.something before, but the download speed there is deffenetly some
improvement and I belive it has to do with the change of router. Infact, the problem where my internet conection drops is still
happening the only difference is that now I am able to disconect the router through the browser not like with the Voyager 2091,
which as you all remember I had to diconect and reconect manually, cos' I couldn't do it through the browser... I will take thoes
pictures some time this afternoon I have some visitors comming shortly for a couple of hours, and I will also post you some more stats.
See you later and thank you for your help!
Re: My Opinion
09-05-2009 12:05 PM
Re: My Opinion
09-05-2009 4:31 PM
Firewall Enabled
Broadcast Enabled
NAT Enabled
UPnP Enabled
Downstream Upstream
Data rate 1856 448
Noise margin 9.3 12.0
Output power 16.9 12.4
Attenuation 63.0 31.5
Ok ... This is the picture from the inside of that extension socket next to the NTL box.
Don't forget this extension socket is not connected anymore to the main BT box.
Re: My Opinion
09-05-2009 5:08 PM
Also have a look at the rear of that bedroom socket and the wiring there - picture again would be useful.
- « Previous
- Next »
