My FTTC connection appears to have nearly halved in speed in both directions
- Re: My FTTC connection appears to have nearly halv...
25-09-2013 9:58 PM
Re: My FTTC connection appears to have nearly halved in speed in both directions
25-09-2013 10:35 PM
The BT wholesale checker is still reporting lower speeds than other sites!
26-09-2013 12:55 AM
26-09-2013 7:46 AM
26-09-2013 8:37 AM
Quote from: deathtrap ...that graph and a couple others aren't looking good, and IMO that graph clearly shows congestion as to where that is ,well plusnet should be in a better position to know more about it...
Well after that is when I got a good rise in speed back to normal so I guess I must have been effected, I wonder if there was a fault causing that?
26-09-2013 9:09 AM
Hopefully people can see the BT Wholesale pic, I couldnt do a screenshot for some reason so I did the next best thing. Anyways as can be seen there is a big difference between the first two tests and the BT test! can anyone explain the big differences?
26-09-2013 9:18 AM
26-09-2013 9:44 AM
for reference I get the reverse effect most times between btw tester and the okala(speedtest.net) ones
26-09-2013 11:07 AM
26-09-2013 11:37 AM
Most people get as good (or better) with HTTP x 6 than with the TBB custom (green line on graph) but I have discovered that the HTTP x6 and BT results can be much more readily influenced by processor speed / loading and antivirus/firewall. Just a thought.
