My Exchange 21CN WBC enabled
- My Exchange 21CN WBC enabled
09-12-2011 2:37 PM
Can I have the upgrade please
To be is to do - Kant
do be do be do - Sinatra
Re: My Exchange 21CN WBC enabled
09-12-2011 2:53 PM
I've done that for you now, I'll confirm it by email/ticket shortly.
Jojo
09-12-2011 2:56 PM
09-12-2011 3:41 PM
09-12-2011 4:00 PM
Due to be completed on the 16 Dec
"we wish you a merry Christmas, we wish you a merry Christmas, we wish you a merry Christmas, and a happy new experience with PN ;D"
16-12-2011 2:16 PM
see below
Uptime: 0 days, 3:51:37
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,364
Bandwidth (Up/Down) [kbps/kbps]: 440 / 5,848
Data Transferred (Sent/Received) [MB/MB]: 23.93 / 106.71
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 20.0 / 41.5
SN Margin (Up/Down) [dB]: 24.5 / 9.0
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 32 / 10,900
CRC Errors (Up/Down): 1 / 25
HEC Errors (Up/Down): 1 / 87
But my PN profile has fallen to 3.5 Mbps
Do I wait for an 88.2% reset or does it need a nudge?
16-12-2011 3:27 PM
It has indeed completed - I've upped the profile on your account to 5800 to match the current sync rate, hope that helps and speeds things up for you
19-12-2011 9:41 AM
since my last post my profile has not moved from 5.8
is it stuck?
Is it affected by a 10 day training period?
Uptime: 2 days, 22:44:08
Maximum Bandwidth (Up/Down) [kbps/kbps]: 888 / 6,376
Data Transferred (Sent/Received) [MB/GB]: 347.90 / 4.96
SN Margin (Up/Down) [dB]: 24.0 / 9.0
Error Seconds (Local/Remote): 131,081 / 0
FEC Errors (Up/Down): 144,160 / 18,484,987
CRC Errors (Up/Down): 1,281 / 22,350
HEC Errors (Up/Down): 1 / 353,644
19-12-2011 9:57 AM
Plusnet match BT's IP profile (and round down to the nearest 100 afaik) rather than the sync speed shown on the router.
What does BT's speed test say? http://www.speedtester.bt.com/
19-12-2011 10:30 AM
28-12-2011 10:04 PM
I am puzzled that my bandwidth stays fixed at 5.8 Mbps while my max bandwidth varies between day and night.
Shouldn't one be following the other?
Uptime: 12 days, 11:38:20
Maximum Bandwidth (Up/Down) [kbps/kbps]: 16,062 / 5,664
Data Transferred (Sent/Received) [GB/GB]: 1.25 / 19.93
SN Margin (Up/Down) [dB]: 24.5 / 6.0
Error Seconds (Local/Remote): 131,098 / 0
FEC Errors (Up/Down): 577,060 / 26,815,130
CRC Errors (Up/Down): 1,281 / 27,364
HEC Errors (Up/Down): 1 / 401,516
28-12-2011 10:16 PM
You could try tomorrow during the day (when the bandwidth is highest), doing a router [DISCONNECT] and then [CONNECT] using the router web page controls, and see if the bandwidth changes.
28-12-2011 10:22 PM
Ive done my duty and not touched the router for twelve days
I feel a good "hacking session" coming on
29-12-2011 2:24 AM
The bandwidth remains constant while sync is maintained with the exchange.
In the absence of a better explanation my speculative take on the bandwidth/maximum bandwidth relationship is as follows.
I think maximum bandwidth reflects what bandwidth you are likely to sync at if you did restart the router. Except for those so close to the exchange that they have noise margin to spare, if current noise margin is greater than the target value then maximum bandwidth will normally be above current bandwidth. Typically this occurs during daylight hours. Conversely if current noise margin is below the target value then maximum bandwidth will be below current bandwidth. This is generally the case at night.
The grey area is when the current noise margin and target noise margin values are roughly equal. I suspect maximum bandwidth can be higher or lower than current bandwidth in this situation because the bit loading distribution probably comes into play. If the router thinks bit loading is becoming marginal (for maintaining sync) then maximum bandwidth will be reduced.
30-12-2011 12:08 PM
