My Broadband Speed
- My Broadband Speed
My Broadband Speed
30-12-2012 8:22 PM
Dear JoJo
In the past you have been able to sort this speed problem
Achieved speed much lower than profile.
Looking at profile speed I would have thought it should be higher any how
Many thanks
Broadmar
Download speedachieved during the test was - 2.91 Mbps
For your connection, the acceptable range of speeds is 1.2 Mbps-4 Mbps.
IP Profile for your line is - 4.17 Mbps
Upload Speed
0.89 Mbps
0 Mbps 0.83 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 0.89Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
Many thanks
Broadmar
Upload Speed
0.89 Mbps
0 Mbps 0.83 Mbps
Message 1 of 7
(1,918 Views)
6 REPLIES 6
Re: My Broadband Speed
30-12-2012 8:34 PM
Hi Broadmar,
I've just changed your speed profile on our side to 4100Kbps so you should see it pick up a little shortly. I am surprised your speed is not greater though. I've just checked your line and I see that your attenuation is 37dB and although your downstream SNR is 6dB your sync speed is only 4723.
How is your kit set up?
Are you using extension sockets/cables?
What router are you using?
Do you have a test socket that you could plug into?
Jojo
Jojo
Message 2 of 7
(1,105 Views)
30-12-2012 8:36 PM
What does this say for Current Line Speed https://portal.plus.net/my.html?action=data_transfer_speed
What the devil is she doing here - and on a Sunday as well
Message 3 of 7
(1,105 Views)
30-12-2012 8:56 PM
Merry Christmas to you too, Jim
Message 4 of 7
(1,105 Views)
30-12-2012 9:17 PM
JoJo - is what your signature says correct?
[me=jelv]Crosses fingers and hopes[/me]
Message 5 of 7
(1,105 Views)
02-01-2013 11:06 AM
Message 6 of 7
(1,105 Views)
02-01-2013 11:07 AM
You know what I meant!
Message 7 of 7
(1,105 Views)
