Must I have ADSL2+ ? it's rubbish compared to what PlusNet supplied before!
- Re: Must I have ADSL2+ ? it's rubbish compared to...
13-08-2012 7:26 PM
Ever since the upgrade a few months ago the reliability is rubbish.
I used to get about 4.5MBPS downstream and 380KBPS upstream and it worked reliably.
Now I get 7.7MBPS down and 660KBPS up but it falls over most evenings at about 9pm.
I was totally happy with the old speed and reliability.
This chase for speed is mad, reliability is much more important.
Can it be turned back to what we had before?
Chris
Re: Must I have ADSL2+ ? it's rubbish compared to what PlusNet supplied before!
13-08-2012 7:30 PM
I did that because ADSL2 with uncapped upload was unstable for me
14-08-2012 6:51 AM
14-08-2012 4:21 PM
14-08-2012 9:15 PM
Fortunately there is a solution as Plus net have finally a fiber product that fits our needs! I don't understand why they moved me back to ADSL2+ on the first of August!
14-08-2012 10:30 PM
Question:
If I stay on 21CN but revert to ADSL1, do I still get the advantage of more or less instant profile of 88·2% of sync?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
14-08-2012 10:35 PM
However
If you resync fairly soon after the drop it seems to miss the drop in the Delta reports
14-08-2012 10:39 PM
So far so good with the settings I am on
I have found the Profile to sort itself out immediately the router is rebooted or within a couple of hours or circa 11-12mdt that night.
Alex
15-08-2012 9:13 AM
17-08-2012 2:30 PM
Yes it was about February you changed things.
I am, I think 5KM from the exchange and have about 30 metres of drop wire feeding my house (I think it's 2 x twisted pairs in the black sheath).
Your system suggests I will get 3 mbps, but I get up to 7.7 mbps.
Many of the disconnections will be due to the noise margin dropping to 0dB after 9PM each evening, maybe medium wave broadcast pick-up on the drop wire?
I was happy with the 4.5mbps and reliable connection I had before February, what would ADSL1 do for me?
Regards,
Chris
