Multiple IPs
- Multiple IPs
Multiple IPs
23-05-2011 1:28 PM
Seems you need a business account to get more than a single static IP.
Really simple - my firewall doesn't allow UPnP, so easiest solution for me, is set each up on seperate firewalled external IP, forwarding the required ports.... but I only have one static IP, and my homebrew mailserver/webserver runs on that already.... would be a shame to take them offline/reconfigure everything everytime I wanted to play online.
CS said I'd need a business account, but as I'm on FTTC, I don't see any business FTTC offering, it'd be a big step back.
Any ways round this, any suggestions?
Message 1 of 5
(627 Views)
4 REPLIES 4
Re: Multiple IPs
23-05-2011 3:08 PM
Hi phil4,
We can change you over to business and you can stay on FTTC, just give our customer services team a call and they'll sort it out for you.
Jojo
Jojo
Message 2 of 5
(317 Views)
Re: Multiple IPs
23-05-2011 3:22 PM
Why don't you just forward the required ports from the single external IP (i.e. PAT)? I appreciate that UPNP may well be quicker/easier but manual port fowarding isn't that difficult and ought only be a one-off exercise anyway. I am assuming of course that these games can use the same port(s) all the time (it'd be a bizarre design if they didn't/couldn't).
Mathew
Mathew
Message 3 of 5
(317 Views)
Re: Multiple IPs
23-05-2011 4:33 PM
Thanks to both, feedback appreciated.
MJN - PAT doesn't work, as the ports are already in use.
Message 4 of 5
(317 Views)
Re: Multiple IPs
23-05-2011 8:01 PM
Ah, okay - see where your predicament lies now.
Mathew
Mathew
Message 5 of 5
(317 Views)
