Much slower Broadband (Fibre)
- Re: Much slower Broadband (Fibre)
09-06-2013 10:41 PM
09-06-2013 10:55 PM
09-06-2013 11:04 PM
My speed has been at a steady 46-47 down and 8-9 up through multiple speed tests since I got fibre and this is the first problem I've had.
09-06-2013 11:07 PM
09-06-2013 11:10 PM
09-06-2013 11:14 PM
You could try switching gateways
In the router GUI - NOT the modem - select disconnect and after a minute or so reconnect.
This wouldn't affect the sync but it will get you on a new gateway
Any better
09-06-2013 11:20 PM
09-06-2013 11:33 PM
10-06-2013 12:00 AM
10-06-2013 1:05 PM
Hope it has, but if not raising a fault would definitely be the best thing to do. Our team will then get on and get it investigated and sorted for you.
10-06-2013 8:50 PM
Edit: My current line speed has dropped from 47.2 last night to 45.2.
10-06-2013 9:11 PM
You need to complete it for the fault to be investigated
10-06-2013 9:45 PM
11-06-2013 9:31 AM
