Moving master socket cost? Rewiring other stuff
- Moving master socket cost? Rewiring other stuff
Re: Moving master socket cost? Rewiring other stuff
21-04-2011 12:03 PM
Being honest one school of thought could be that the only way to find out is to go ahead and get the job done. However I'm more inclined to think that the improvement may be minimal when weighed up against the financial cost.
21-04-2011 9:42 PM
Quote from: Ben
If we go through the faults process, for instance if you experience an intermittent connection or significant deterioration of your speeds then we can send an engineer out who is authorised to enact whatever repair work is necessary and is likely to replace that sort of wiring if you ask nicely (and provide tea and biscuits).
Hmnn interesting, we had a bt engineer round when I was with TT ( ) he took one look at the wiring, shook his head and quickly sodded off back to the cabinet and exchange :D.
Funny you should mention disconnections I do seem to be getting a few over the last few days which in truth I haven't had before.
So have a quick look at your end and deceide to send an engineer to replace the master, I'll stay for another year I promise
22-04-2011 3:17 PM
22-04-2011 5:12 PM
and this is my BT speed test result, should I do anything about it, will it speed up my surfing and e-mail, I dont game or P2P
22-04-2011 5:27 PM
Ben can you fix it by putting him on a 2mb fixed profile
22-04-2011 5:50 PM
How does the BT test get its result?
my set up a Thomson 585 v7 Release: 8.2.6.5 feeding a SamKnows Linksys via ethernet, Normally I use WiFi from the Thompson, but my synch dropped on the 25th March.
I waited for it to come back up, but no, Had another query recent so decided to run my desk top via ethernet (via the Linksys), now got my Synch speed back
Why as both routers are on 24/7, surely the BT would not know the difference?
22-04-2011 5:53 PM
Quote from: Ben 2 drops in 7 days isn't really enough to warrant us sending an engineer, sorry!
Well you've got to try
26-04-2011 9:52 AM
26-04-2011 9:59 AM
Quote from: Oldjim Obviously Pierre has a problem.
Certainly looks like it.
I'd suggest you start your own thread and describe all the wiring in more detail, including posting a larger photo that clearly shows the connections.
26-04-2011 10:19 AM
The wire comes from the eves down the cavity wall and out of an air vent in the under stairs larder to the box, they fitted a socket on the bedroom extension, which I think is connected in a junction box in the loft where the wire disapears down the cavity - it is not a master box. At the same time they ran a short extension through to the hallway and a single socket wher I now have the Thompson and Samknows router.
This was at the time when BT stopped supplying phones and you could buy your own
More than happy with my speed, could probably get more but dont care
The upstaits line is to SWMBO craft room, done by me about 15 years ago
26-04-2011 11:46 AM
also got this interesting email today
When you signed up for your broadband account, we performed a check on your telephone line to give you an estimated speed your line might achieve.
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 18Mbps
Current line speed: 13Mbps
hmmmmm.
26-04-2011 4:39 PM
If it's not broken...!
26-04-2011 6:39 PM
point I was trying to put with tongue in cheek
all pasted above is correct by the way, just noted third wire, but who cares
26-04-2011 6:49 PM
Quote from: _Adam_Walker_ john50,
You may wish to weight that up against the cost of moving the socket. BT engineers can now charge a £100 call out fee plus £65 per hour for jobs like that.
I hate to give you some bad news but you will have to parts on top of the £100 call out and £65 per hour.
Last time I had a quote BT wanted to charge me £40 a extension socket
Puddy
26-04-2011 7:38 PM
PPPOA instead of PPPOE
Forced 3.5DB instead of 6.3DB
pushed up my sync up by around 2000kbps
I think thats as much as i can do a part from enabling interleaving which i may try at some point.
Noise Margin: 3.5 dB
Connection Rate: 16112 Kbps
Line Attenuation: 25.5 dB
Power: 0.0 dBm
Max Rate: 19076 Kbps
SuperFrames: 42477
SF (CRC) Errors: 11
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 9
Errored Seconds: 13
Severe ES: 0
Interleave Depth: 1
Bitswaps: 5
Noise Margin: 11.5 dB
Connection Rate: 984 Kbps
Line Attenuation: 14.8 dB
Power: 11.6 dBm
Max Rate: 988 Kbps
SuperFrames: 39279
SF (CRC) Errors: 0
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 2
