Modems in Bridge Mode
- Re: Modems in Bridge Mode
01-11-2012 11:57 AM
We have just moved one of our remote sites over to PlusNet ADSL and I'm trying to set up our Billion BiPAC 5200 modem/router and Netgear FVS338 VPN Firewall Router.
With our previous ISP (Mistral Internet) I put the Billion into bridge mode and entered the PlusNet credentials into the FVS338. However, the FVS338 isn't seeing the internet.
To keep things simple I disconnected the FVS338 and connected a laptop running XP Pro directly to the Billion. I then set up a dial up account but that wouldn't connect either.
I then swapped over the hardware for identical models with no success.
Moving the whole setup over to an adjacent BE Internet line all worked well.
PlusNet Business support couldn't help (they didn't seem to know what a brdsge mode was) so I'm wondering if there is something about PlusNet's service that prevents this type of connection.
If anyone has any ideas I could try I'd be really grateful.
Regards,
Richard.
Regards,
Richard.
Message 1 of 4
(936 Views)
3 REPLIES 3
01-11-2012 12:08 PM
Do you need to change the VPI /VCI settings in the modem for PlusNet ?. It should be VPI = 0 VCI = 38
Message 2 of 4
(508 Views)
01-11-2012 12:17 PM
Quote from: Waggers I'm wondering if there is something about PlusNet's service that prevents this type of connection.
Plusnet is one of many ISPs that use BT infrstructure. Anyway, you have tried bridge mode and non-bridge mode. Are you sure Plusnet has actually taken over your broadband connection yet?
Message 3 of 4
(508 Views)
01-11-2012 1:56 PM
Thanks for the replies.
ReedRichards: Yep, pretty sure - If I put the modem into non-bridge mode and use the PlusNet credentials all works fine.
MisterW: Yep, I've double checked and it is, indeed VPI = 0 VCI = 38
Message 4 of 4
(508 Views)
