Migration to Plusnet - new line training period?
- Re: Migration to Plusnet - new line training perio...
13-11-2007 3:02 PM
I'm migrating to Plusnet at the end of the month. I have a very good ADSL max connection with my current ISP and typically get around 6,200kbps thoughput speed (Downstream 8,128 and IP profile 7,150).
My question is: when I migrate will I go into another line testing period or will it automatically sync at the current speed? If the former, what are the chances of (eventually) getting a similar speed?
Message 1 of 3
(1,441 Views)
2 REPLIES 2
Re: Migration to Plusnet - new line training period?
13-11-2007 3:19 PM
You shouldn't need to go through another training period, this only happens when the line is activated for the first time. As such you should maintain the same speeds.
Hope that helps,
Hope that helps,
Message 2 of 3
(390 Views)
13-11-2007 3:23 PM
OK. Thanks for the information.
Message 3 of 3
(390 Views)
