Migrated to fibre, getting same speed
- Migrated to fibre, getting same speed
29-11-2013 2:41 PM
Is this low speed to be expected because it is only starting or is there something wrong with the setup? The internet and Ethernet lights are constantly flashing in the router, if that is if any significance.
Thanks for your help
Re: Migrated to fibre, getting same speed
29-11-2013 2:45 PM
29-11-2013 2:52 PM
Sounds like your PlusNet profile hasn't caught up with the change to Fibre.
29-11-2013 2:54 PM
(There's no prioritisation on the upstream, so that doesn't need to update.)
You can either wait a while for it to update automatically or just give PlusNet a quick call and ask if they wouldn't mind doing it manually so you can get on an see how fast it really is
29-11-2013 3:00 PM
It says:
Estimated line speed:
47Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-11-29 12:21:04
Current line speed:
5.4 Mb
I guess I just have to be patient.
Thanks again
29-11-2013 3:18 PM
Quote from: Lacandon I guess I just have to be patient.
The "Current Line Speed" is the PlusNet profile.
As I say, you can call. Or one of the Digital Care Team on here can no doubt do it for you.
There's a schedule for the update script, though, so it will happen eventually if you are happy to wait.
Just for anyone else who comes along, this is incorrect:
Quote from: davidwalker900 there is 14 days cool off leave the router on and modem it will get the right speed in 14 days
There is no initial training period for DLM on FTTC:
http://www.thinkbroadband.com/news/5929-reminder-about-the-reality-of-dlm-on-openreach-fttc.html
http://forum.kitz.co.uk/index.php?topic=10513.0
29-11-2013 5:14 PM
29-11-2013 7:54 PM
29-11-2013 9:53 PM
In that time I had a few resets of the modem which didn't seem to affect the speed so I suspect there is no real training period for FTTC - it just adapts as it goes.
29-11-2013 9:54 PM
Thanks for all your replies.
30-11-2013 1:16 PM
Can't read off the full chart, even with correction...
30-11-2013 1:43 PM
Are you sure you are not confusing the 14 day cooling-off period of your contract with the line training of ADSL.
As @SuperZoom has stated: "There is no initial training period for DLM on FTTC."
There is a 10-Day training period for ADSL
Kind regards,
30-11-2013 2:26 PM
01-12-2013 1:49 PM
Quote from: Lacandon Hello, I have migrated from ADSL to fibre. The Openreach engineer came today to set up the modem and router. On his tests from the modem, he was getting 69 Mbps. After he left I configured my computers and started using the broadband. I am getting speeds of around 5 Mbps on the download (which is not very far from what I used to get with ADSL), although I get 14 Mbps for upload. I have tried both over witless and Ethernet.
When conducting tests don't use Wireless adapters, this is because you'll only get real results over ethernet cabled adapters.
It sounds very much as if there is something incorrectly set up at modem-router level for there to be such a disparity between the BT engineers reading and your own!
It's also possible that the ethernet adapter you're tapping in from isn't set-up properly.
